Home > Technical (L322) > 2006 SC zf gearbox issues
Mart67
2005 Range Rover Supercharged 4.2 SC V8 Java Black
Morning all,
My gearbox appears to have a mind of its own lately, shifting when it wants, on light throttle it can’t seem to sit in one gear so it keeps changing between 2, this subsiquently gives me the transmission fault, limited gears only displayed. If you don’t quite stop at a junction then pull away it delays, engages first gear and gives you a jolt back in your seat as it pulls away?? Sometimes it want change gear until 4.5k and other times it’s good as gold?? Need it sorting as it’s nit right.Once this happens I just turn the ignition on and off and it’s fine again. Seems fine on the motorway and fine if you drive it rather spirited but it just isn’t right. Has anyone had anything similar?? Gearbox has recently had an oil and filter change as I had a few transmission fault messages some time ago.
Help!!
Post #482323 1st Jul 2018 11:19am
Mikey
How recently was the oil replaced?
What spec of oil was used?
How many miles on the car?
Were the issues present before the oil change?
Post #482327 1st Jul 2018 12:10pm
Mart67
Oil changed around 300 miles ago, I’ve has maybe 2 issues in the past where I’ve had the transmission fault messsge but nothing like it is now?
I’d have to check oil speck but it was done at a reputable specialist so I’m not too worried about the incorrect oil being used, the cars find 124k.
Post #482350 1st Jul 2018 5:21pm
Mart67
It appears to get all gears perfectly if you drive it in sport mode and manually select the gears, I’ve noticed that when stopping in sport mode it doesn’t select first every tine but will if you manually select it? Can anyone second my findings? Or has anybody had anything similar.????
Post #482355 1st Jul 2018 6:13pm
400-ascona
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
Could be bush leaks. When you run in manual/sport it ups the pressure in the system to make sure it's ready to change gear whenever needed. This therefore covers the loss of pressure from the leaking bushes. Prolonged use of manual or sport means the box runs hotter which is also detrimental long term.
This is what I was told by a couple of ZF specialist.
Rob 05 L322 4.2SC
2016 Discovery 4 Graphite
Lotus Carlton
Ascona 400
Volvo V70R AWD manual
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Mini Cooper S Works 2006
Post #482372 1st Jul 2018 9:17pm
Glynn
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Bet it needs a new Mechatronic unit.
These gearboxes are notorious for it, must be one of the worst autos made.
Post #482413 2nd Jul 2018 12:37pm
Mart67
This is what I’m thinking, reading articles on the net it appears the mechatronic unit is Censored at best.
It’s odd as it performs faultlessly if I drive it in sports mode manually shifting. I could do with someone else checking if there car down shifts to 1st gear in sports mode as mine won’t. If you go to pull away in second the revs raise but then it selects first and gives you a jolt as you pull away. If you manually select first then shift up through the gears it’s perfect.
Post #482420 2nd Jul 2018 2:48pm
Glynn
It'll just gey worse over time, mine ended up with a rebuild and new mechatronic unit & new torque converter.
Post #482421 2nd Jul 2018 3:06pm
