![]() | Home > Technical (L322) > 4 zone climate control. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7864 ![]() ![]() ![]() |
4 zone is as it says really....each side of rear passenger area can be set different. Standard is just 2 zone, passenger side and drivers side. If passenger behind driver wants it hot, and drivers has set cold, they are out of luck. With 4 zone they can choose their individual temp.
mcj0rdan Member Since: 27 Aug 2016 Location: Crediton Posts: 18 ![]() ![]() |
Thank you for your detailed reply. Do I assume the front controls stay the same, the difference being the extra rear controls? |
Yeah, there are 3 control knobs on the back of the centre console in the rear, instead of just 2. 2011 Range Rover Vogue SE 4.4 TDV8
Thanks again for your help. MJ |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
I'd love to upgrade mine, the two-knob standard set up is pretty average
Don’t think I’ve ever travelled in the back of mine.
Sorry to report, the HD is
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1453 ![]() ![]() |
I don't think an upgrade is that easy (maybe not even possible). 4 zone systems have an additional evaporator fitted beneath the centre console cubby box which is why, on 4 zone systems the box is very shallow. 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
Thanks Mr double r
sorry to stray back to the merits of HD audio, I was driving with the HD cranked the other day and I noticed my jean leg was moving from the air being pumped by the lower door speaker.
