Home > Technical (L322) > 4 zone climate control.
mcj0rdan
Ref 2010 5.0 Supercharged Autobiography.
Can anyone tell me the difference between standard climate control and optional 4 zone climate control?
Thank you,
Mike.
Post #481893 26th Jun 2018 11:56am
mjdronfield
4 zone is as it says really....each side of rear passenger area can be set different. Standard is just 2 zone, passenger side and drivers side. If passenger behind driver wants it hot, and drivers has set cold, they are out of luck. With 4 zone they can choose their individual temp.
There is an extra air con pump or something in the rear and if you have the air con regaled, you will need more putting in if it has 4 zone. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #481916 26th Jun 2018 4:26pm
mcj0rdan
Thank you for your detailed reply. Do I assume the front controls stay the same, the difference being the extra rear controls?
Post #481920 26th Jun 2018 4:52pm
mjdronfield
Yeah, there are 3 control knobs on the back of the centre console in the rear, instead of just 2. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #481921 26th Jun 2018 5:11pm
mcj0rdan
Thanks again for your help. MJ
Post #481932 26th Jun 2018 9:26pm
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #481934 26th Jun 2018 9:38pm
GGDR
I'd love to upgrade mine, the two-knob standard set up is pretty average
I'm sure it's not straightforward though.... Cheers, Greg
Post #481935 26th Jun 2018 9:41pm
mjdronfield
Don’t think I’ve ever travelled in the back of mine.
Just wish I had the HD stereo.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #481936 26th Jun 2018 9:46pm
GGDR
Sorry to report, the HD is
E P I C
It's not doing my hearing any good.
. Cheers, Greg
Post #481937 26th Jun 2018 9:54pm
Rob99
I don't think an upgrade is that easy (maybe not even possible). 4 zone systems have an additional evaporator fitted beneath the centre console cubby box which is why, on 4 zone systems the box is very shallow. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #481941 26th Jun 2018 10:42pm
mjdronfield
Thanks Mr double r
Rolling with laughter
I have a LINN hi fi in the house, but I listen to more music in the car....
On topic....I recon it’s easier to swap cars sometimes than rip it all apart and try and redo what the factory did.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #482020 27th Jun 2018 6:39pm
GGDR
sorry to stray back to the merits of HD audio, I was driving with the HD cranked the other day and I noticed my jean leg was moving from the air being pumped by the lower door speaker.
It is unbelievable.
Probably should turn it down a bit though.
Ok back to 4-zone climate....
. Cheers, Greg
Post #482026 27th Jun 2018 7:37pm
