Home > Maintenance & Mods (L322) > Leaving FF on axle stands.
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
Going to get the wheels powder coated.
I can't get my mitts on a spare set of wheels, so would it be ok to leave the motor on heavy duty axle stands for a couple of days?
I'm not happy about it, but I've no alternative at the moment Embarassed
Post #480675 11th Jun 2018 12:11pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
I would think no problems as mine was on axle stands for a couple of weeks recently when I worked on it.
I would suggest when you have got your wheels back on drive fairly slowly for a couple of minutes
for the suspension to reset itself.
Mine sorted itself out with no warning bongs so it should be ok for you as well Thumbs Up .
Post #480676 11th Jun 2018 12:28pm
Rob99
It should be fine but make sure it's supported under the structural chassis and not any of the suspension components. 2017 4.4 SDV8 Autobiography
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #480682 11th Jun 2018 1:06pm
Should be fine sir... My classic LSE has been suspended for the past month or so!
Post #480687 11th Jun 2018 2:03pm
steptoe
Had mine shot blasted and powder coated (all over, not just the faces) in satin black, £40 each.
Bought five goodyear tyres with delivery mileage on them from a forum member on a bike forum i belong to, taken off a brand new land rover because the owner preferred a different brand of tyre and didn't want the originals back. .
Chucked in the back of the RR.
And down to my mates tyre garage to fit them.
Post #480702 11th Jun 2018 4:41pm
Wogger
Cheers chaps
Gonna fit a new grille while I'm at it as well
Post #480710 11th Jun 2018 6:11pm
Shouldn’t be a problem if you carefully position them. There is nothing that can't be fixed with a hammer😜😜
Post #480714 11th Jun 2018 6:53pm
GGDR
steptoe where did you get your rims done?
. Cheers, Greg
Post #481324 19th Jun 2018 5:06am
p38arover
Australia
Why? When the car is on it's wheels, it is supported on its suspension components.
I'd put the axle stands under the suspension - if you don't you're going to have to lift the car very high to remove the wheels and the suspension will be left hanging. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #481330 19th Jun 2018 6:59am
nino_nino
+1
Post #481339 19th Jun 2018 9:16am
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
after mine fell over last week and snapped my 3 tonne axel stands I have 6 tonnes stand firmly on the non wobbly structural chasis
Post #481343 19th Jun 2018 11:06am
Rob99
I agree that having an axle stand under a roll bar or lower wishbone would be fine for changing a wheel or working on one corner for a few hours, but I wouldn't want to have all 4 corners supported that way for several days. 2017 4.4 SDV8 Autobiography
Post #481349 19th Jun 2018 12:46pm
