Home > Maintenance & Mods (L322) > Leaving FF on axle stands. |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 503 |
I would think no problems as mine was on axle stands for a couple of weeks recently when I worked on it.
11th Jun 2018 12:28pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1425 |
It should be fine but make sure it's supported under the structural chassis and not any of the suspension components. 2021 D350 Fifty Edition - Carpathian Grey
11th Jun 2018 1:06pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Should be fine sir... My classic LSE has been suspended for the past month or so! |
11th Jun 2018 2:03pm |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
Had mine shot blasted and powder coated (all over, not just the faces) in satin black, £40 each.
11th Jun 2018 4:41pm |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 |
Cheers chaps
11th Jun 2018 6:11pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8530 |
Shouldn’t be a problem if you carefully position them. There is nothing that can't be fixed with a hammer😜😜
11th Jun 2018 6:53pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
steptoe where did you get your rims done?
19th Jun 2018 5:06am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1534 |
Why? When the car is on it's wheels, it is supported on its suspension components. I'd put the axle stands under the suspension - if you don't you're going to have to lift the car very high to remove the wheels and the suspension will be left hanging. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
19th Jun 2018 6:59am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
19th Jun 2018 9:16am |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
after mine fell over last week and snapped my 3 tonne axel stands I have 6 tonnes stand firmly on the non wobbly structural chasis |
19th Jun 2018 11:06am |
I agree that having an axle stand under a roll bar or lower wishbone would be fine for changing a wheel or working on one corner for a few hours, but I wouldn't want to have all 4 corners supported that way for several days. 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
19th Jun 2018 12:46pm |
