Home > Maintenance & Mods (L322) > 3.6 TDv8 / ZF6HP26 Gearbox Oil Change |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 688 |
I finally got round to changing the gearbox oil in our 124k miles ZF6HP26 equipped 3.6 TDV8 2 days ago (delayed due to me being a wimp & not wanting get underneath while the weather's been foul).
23rd Apr 2018 2:37pm |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 516 |
Excellent write up of a job near the top of my list - I have the plastic sump from AF in the garage along with 7l of oil.
23rd Apr 2018 9:06pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8503 |
If you have the sump off and the oil dropped, it’s worth changing the sleeve, after all if it starts leaking a month after swapping out the expensive oil you will be most peeved!!
23rd Apr 2018 9:14pm |
You've convinced me. Add it to the list... 2016 Skoda Octavia VRS Estate
23rd Apr 2018 9:17pm |
disco 3.5 Member Since: 14 Aug 2014 Location: barton seagrave Posts: 35 |
hi pawl did you get any quotes by a garage on how much a gear box oil change would cost, mine needs changing but im not confident to tackle it my self, ive been quoted £450, is that competitive LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER |
16th Jun 2018 4:48pm |
When I did my 2007 I bought the stuff from Dan and then got the M.D. to do it, the labour charge was about £100 but that was a few years back. There is nothing that can't be fixed with a hammer😜😜
16th Jun 2018 5:45pm |
I didn't get a quote for an oil change, because I'd seen so many comments initially suggesting a "simple" oil change didn't change a high % of the transmission oil. It was only later I realised that these were related to the GM 5 speed gearbox & that the few who'd changed the oil on the 6 speed had all changed the major part of the oil. Via a couple of on-line videos, I then realised it was well within my DIY skills & left me in full control of what was done / not done (I have fully developed paranoia about the reliability / cost of garages ) The quotes for the mega flush did highlight that many garages will only use the transmission oil they get a good deal on OR charge very significantly more to use the very strongly recommended ZF Lifeguard 6 fluid. The recommended oil & sump pan / filter cost me about £220 from memory, labour obviously free. That suggests the £450 is a bit high (at least to me), as a garage ought to be able to buy the fluid & sump cheaper & should have facilities which make the job faster than my very leisurely total of maybe 4 hours ( excluding waiting time for everything to drain while I was doing other things / drinking tea . I think the key questions are what fluid are they proposing to use, what will it cost for ZF Lifeguard 6 & are they including changing the mechatronic sleeve mentioned via a few of the posters above. Hopefully you'll get some more feedback on garage costs here soon. Good luck. Paul, 2001 Discovery 2 TD5, 211,000 miles & climbing 2006 FFRR TDV8 Vogue 145,000 miles & climbing Member of Midland (Land) Rover Owners Club, www.mroc.co.uk |
16th Jun 2018 6:34pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Great write up Paul.
16th Jun 2018 8:30pm |
thankyou pawl for your reply, very usefull information for me to take to the garage, ive got a number of questions to ask them thanks to your excellent write up don't fancy changing my oil do you lol LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER |
17th Jun 2018 8:47am |
disco 3.5 thanks for the kind offer of work !
17th Jun 2018 9:29am |
Thanks Pawl anyway Im more educated for speeking to you, will search for some mechanic who will use the right parts and who is recommended to do a top job LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER |
17th Jun 2018 10:16am |
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 |
My local specialist quoted £300 for a mega flush oil change on our ‘07 TDV8.......only on 89K presently and running sweet, but will get it done this year. David
17th Jun 2018 10:25am |
what garage quoted you that price bowbrownie LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER |
17th Jun 2018 10:38am |
Triumph72 Member Since: 11 Apr 2018 Location: Argyll Posts: 39 |
Does anyone know if LR does the gearbox oil change as part of a regular Service?
17th Jun 2018 11:25am |
