Home > Maintenance & Mods (L322) > new jack
Baltic Blue
Sorry, I think the photo goblin has eaten all my old post photos, but , I will take some new ones tomorrow and add them to this post.
Post #480717 11th Jun 2018 8:10pm
Baltic Blue
As promised.
Take care not to let the piston fall whilst the top is removed.
The drilled top
I use an old nail to hold it on.
Post #480744 12th Jun 2018 9:08am
dirtymonkey38
Star as always....i take it the 2.6ton sprinter jack is the one to get. That aluminium plate is expensive 2011 RR Autobiography 4.4 TDV8
Post #480906 14th Jun 2018 5:10pm
the ally adaptor is easy to mill to size at home with some drills, I did mine with a wood spade bit s I didn't have the right sized metal bit. The ally is soft so it will drill with pretty much any old POS drill. Thumbs Up The sprinter is the way to go its so much better than a trolley on anything other than smooth concrete, and will lift the car to an astonishing height easily.
I did manage to drill the hole for the roll pin the right size so I reused that rather than a nail, but if it works then all it has to do is hold it on in storage. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #480908 14th Jun 2018 5:23pm
Baltic Blue
I perhaps should have added, that I bent a small kink in the nail, so that it is a tight fit.
I have never needed to remove it since I did the mod until yesterday to take the photographs.
Post #480914 14th Jun 2018 6:50pm
