![]() | Home > Technical (L322) > Replacement boot floor handle |
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 218 ![]() ![]() ![]() |
Foolishly tried to lift the boot floor/spare wheel cover to store something in the spare wheel well at the weekend while there was still some luggage on it. The grab handle promptly snapped under the strain.
Can the handle be replaced or does it mean I have to buy a new boot floor? The underside seems to be stuck on with adhesive so maybe it can be carefully peeled back to allow handle replacement but if it's not available separately I guess I'm not going to find one... 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black 2008 Vogue 3.6 TDV8 automatic (LHD), Java Black |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
deansmith Member Since: 17 Oct 2017 Location: Hertfordshire Posts: 88 ![]() ![]() ![]() |
I've the same issue. What/who is Shuster? Quick google returns a boiler company, amongst others ![]() |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Not available as a separate item, but I’m sure with a bit of ingenuity it’s repairable. There is nothing that can't be fixed with a hammer😜😜
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Buy a new TV. The box will have a suitably sized plastic handle. |
shuster - cobbler, shoemaker, shoe repairer ![]() . |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
I replaced mine with a couple of heavy duty cable ties - downside was that they didn't sit flat - upside was that I could thread them through the existing holes and didn't have to touch the trim. |
Duracell777 Member Since: 07 Sep 2015 Location: Warwickshire Posts: 128 ![]() ![]() ![]() |
Well I finally got around to having a bash at fixing my broken handle. The above replies were helpful in finding a solution that worked. In the end I decided to re-use the leather strap - even though it's in two pieces - and strengthen it with two very large (360x9mm) cable ties. Here are a few pics of what I did to fix it.
