Home > Technical (L322) > Replacement boot floor handle
FrankRizzo
Germany 2012 Range Rover Vogue 4.4 V8 Santorini Black
Foolishly tried to lift the boot floor/spare wheel cover to store something in the spare wheel well at the weekend while there was still some luggage on it. The grab handle promptly snapped under the strain.
Can the handle be replaced or does it mean I have to buy a new boot floor? The underside seems to be stuck on with adhesive so maybe it can be carefully peeled back to allow handle replacement but if it's not available separately I guess I'm not going to find one... 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
2008 Vogue 3.6 TDV8 automatic (LHD), Java Black
Post #480139 4th Jun 2018 7:40pm
nino_nino
schuster can make one for you.
. Thumbs Up
Post #480152 4th Jun 2018 8:45pm
StewD
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I used an old holdall bag strap, unpeeled the underfloor floor sound insulation and secured the replacement strap with heavy duty staples from a staple gun, then reattached the insulation with a few more staples..... jobs a good’un 👍🏻 Current: Supercharged 06 FFRR in Java Black
Previous: BMW 740D M Sport
Previous Previous: BMW 730D Sport
Post #480159 4th Jun 2018 10:26pm
deansmith
United Kingdom 2016 Range Rover Vogue SE SDV8 Carpathian Grey
. Thumbs Up
I've the same issue. What/who is Shuster? Quick google returns a boiler company, amongst others Laughing
Post #480466 8th Jun 2018 7:32pm
Not available as a separate item, but I’m sure with a bit of ingenuity it’s repairable. There is nothing that can't be fixed with a hammer😜😜
Post #480472 8th Jun 2018 8:20pm
Buy a new TV. The box will have a suitably sized plastic handle. Laughing .
Post #480479 8th Jun 2018 9:00pm
nino_nino
deansmith wrote:
. Thumbs Up
shuster - cobbler, shoemaker, shoe repairer
Very Happy
Post #480503 9th Jun 2018 9:58am
I replaced mine with a couple of heavy duty cable ties - downside was that they didn't sit flat - upside was that I could thread them through the existing holes and didn't have to touch the trim.
Post #480510 9th Jun 2018 12:19pm
Duracell777
Cable tie
Post #480527 9th Jun 2018 6:33pm
FrankRizzo
Well I finally got around to having a bash at fixing my broken handle. The above replies were helpful in finding a solution that worked. In the end I decided to re-use the leather strap - even though it's in two pieces - and strengthen it with two very large (360x9mm) cable ties. Here are a few pics of what I did to fix it.
An elastic strap runs through the handle and is attached to the spare wheel cover at each end with a short bolt screwed into the fibreglass and a few staples. My solution doesn't use the screws as it turns the handle into a loop. There is a stiff plastic strip in the handle under the leather and I think one of the ends of this cut into the elastic and the leather, causing it to break. I left it in place to maintain the handle's shape.
I threaded two large cable ties through both parts of the strap (under the leather) from opposite ends so that the buckles would not be next to each other. For this I had to undo the stitching at the ends of the leather strap to allow the ties to slide through. There is just enough room in the strap to allow the two 9mm-wide ties to lie in parallel.
I had to peel back the insulation on the underside somewhat to allow access to the strap.
I threaded the ends of the strap through the two strap holes in the cover and bent the cable ties towards each other and tightened them as much as I could. Most of the adhesive on the insulation was still sticky enough to re-stick it to the cover but it had lost its adhesion in a couple of places so I solved this with some double-sided carpet tape and some fabric adhesive.
The stiffness of the cable ties prevents the handle from lying flat so it remains slightly raised off the floor but it allows easy hand access at least.
It might not be perfect but it will do until I find a cheap replacement spare wheel cover. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Post #616389 14th Dec 2021 8:51pm
