Home > Maintenance & Mods (L322) > rear bushes
Balloonengineer
rear bushes
Hello all
Any hints on in-situ removing the rear lower outer suspension bush (known as the knuckle bush LRO32644)
Has a circlip on the drawing, but I imagine its well rusted in.
My usual method would be to pass a hacksaw through the bush and saw it so it can collapse in in itself, however the replacement bush looks very thick to saw through. I can heat the outer casting, but need to be careful of the CV.
Any tips or gotchas welcome
Thanks in advance
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #480439 8th Jun 2018 3:29pm
there's some stuff in the wiki Glen that might help.. ... - .- -.
Post #480440 8th Jun 2018 3:33pm
From memory the circlip will shift, regardless of rustiness, either it will fall out or disintegrate. Biggest problem for me was finding it in the first place! .
Post #480476 8th Jun 2018 8:49pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Beware : it's not a bush it's actually a ball joint - ie mainly metal, apart from the boots & maybe a thin plastic line for the ball joint.
I changed 1 side of ours yesterday, using 1 of the big "G clamp" type press tools.
Biggest challenge finding the right combination of sleeve diameters & lengths to push it out & pull the replacement in.
While it was disconnected it was very obvious the toe control arm ball joint had got play in it - which I'd failed to notice eith a pry bar with it all together. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #480480 8th Jun 2018 9:01pm
correct term: rose joint Thumbs Up .
Post #480486 8th Jun 2018 10:02pm
p38arover
Australia
See my pix at the end of this thread: http://www.fullfatrr.com/forum/topic13469-15.html Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #480489 8th Jun 2018 10:46pm
Balloonengineer
Thanks Chaps!
Post #480498 9th Jun 2018 7:55am
