Home > Maintenance & Mods (L322) > Brake disc and pads
SinbadRose
Brake disc and pads
Another quick question, The place i got the car from replaced the front pads (about 5k ago, but checking on the MOT etc, it shows that the front discs are half gone, so i want to replace them, is it best to replace the disc and pads, or can i just do the discs?
Post #480261 5th Jun 2018 8:59pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
New discs means new pads always.
Post #480267 5th Jun 2018 10:44pm
as above Thumbs Up
but if they are half gone they also must be half left so why change them? ... - .- -.
Post #480278 6th Jun 2018 7:07am
nemmi69
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Barolo Black
Since there is some disc left I would start shopping around for new disc and pads. Often good deals can be found this way rather than buying straight away. What doesn't kill you is just bidding it's time.
Post #480279 6th Jun 2018 7:30am
SinbadRose
Sorry, got it wrong, the rear are half gone, its the fronts that have the bad cavitation and squeal like a pain in the a$$.
got a price for LR parts, disc and pads all round, Not cheap, so thinking of Brembo discs for front, delph on the rear, then its which pads Sad
Seem to read/hear different stories about all, some say they squeal, so same never had an issue. Either way, need to get it sorted in the next couple of weeks before the next trip
Post #480419 8th Jun 2018 11:51am
nemmi69
If there is plenty of material left on the pads and the discs don't look to bad you could just have so grit trapped which just requires removing the pads and cleaning them and the discs up. I had this after coming of a beach in Cornwall. What doesn't kill you is just bidding it's time.
Post #480420 8th Jun 2018 12:02pm
SinbadRose
Last quick question before i try to clean/re-grease them, I have 3 tonne axle stands (for the pair, not each) are they alright, or better to get heavy duty ones?
Post #480432 8th Jun 2018 1:35pm
Rob99
3 ton stands will be fine..........
.........unless you're planning on balancing the fattie on just 2 of them..... Shocked 2017 4.4 SDV8 Autobiography
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #480433 8th Jun 2018 1:42pm
SinbadRose
Cool, will have a clean up tomorrow if the weather holds, see if it cures it, if not, new disc and pads it will be.
Post #480435 8th Jun 2018 2:07pm
Balloonengineer
I Just did my rear discs and pads a few weeks back, but found fuel consumption dropped and warm wheels.
What had happened, as the pistons were pushed back in they had partially seized, dragging on the disc.
Worth checking by jacking up and spinning the disc after a few miles of bedding in, or if your pistons look a bit corroded, change the calliper, its quite quick and easy to do.
I see quite a few places ask for them as exchange but I bought mine outright, so thinking about shot blasting them and refurbishing them, or just passing them on, or scrap them!
My fuel consumption went up about 8mpg to over 30 mpg! at that rate it will pay back the cost of the callipers quite quickly
Best wishes
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #480442 8th Jun 2018 3:36pm
SinbadRose
Going to try cleaning them out and re-grease first, see if that helps, if not, i will replace disc and pads. Thanks for all the info guys.
Post #480445 8th Jun 2018 4:00pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I Replaced my front disks and pads today with pagid ones
I waited for a sale at euro car parts and got them 50% off Cool
Mine were squealing. On taking the pads out they are about 70% worn, and the disks lipped about 1 to 2mm each side.
A couple of things to note.
The caliper on my 2010 car is held on with a 21mm bihex head bolt, so make sure you have a socket to fit.
Also my wheel nuts had swollen, and some were a right pig to get off.
Hope that helps. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #480464 8th Jun 2018 7:24pm
SinbadRose
All info most welcome. I had the front nuts replaced when they did the brake pipes last month. so they should be fine. Looks like an easy quick job to try the pads first, as i don't think you need to take the caliper off. But if this fails, disc and pads it will be, along with caliper check.
Post #480468 8th Jun 2018 7:45pm
SinbadRose
Well what can i say. Went to do them today, got one side ready to be jacked up, went to do the other side and the Censored locking wheel nut key has broken Censored
Fingers crossed i don't get a puncture before i can get a new one sorted. Censored
Is there a number registered with the locking nut key? and where do you find it?
Cheers all.
Post #480588 10th Jun 2018 1:19pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
The key should have a letter stamped on it? 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #480591 10th Jun 2018 1:27pm
