Home > Maintenance & Mods (L322) > Seized ball joints
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Cheers bud.. wish me luck (I will need it) Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #478969 20th May 2018 2:03pm
Pilgrimmick
Scotland 2004 Range Rover Vogue Td6 Java Black
I just trimmed the ball joint down with a grinder then bashed the remains out with a hammer, was desperate after much previous effort without success. Got enemies? Good, you have stood up for something in your life.
Never regret growing old, it is a privilege denied to many.
Post #479024 21st May 2018 10:19am
scotcruz
Is this the one in the hub/knuckle..
I have 2 issues..
1) the ball joints a seized stuck therefore I can't take the arms off..
2) one of the T50 Torx on the hub has been rounded off..
Left it as is.. Will have another go to see if I can free the arms. I have seen another thread where someone was in a same issue as me and was able to get a socket on the Torx nut and get it off.. Current:
Past:
Post #479043 21st May 2018 12:40pm
scotcruz
Ok folks to finally managed to replace the lower ball joint and the upper and lower control arms.. noise has gone and it drives like a dream.
Basically, the ball joint splitter I had was not big enough. You need a proper 50mm minimum jaw splitter to do the job.. no hammer would do it..
Best to take the disc and caliper off as it gives you good access. Tips for lower ball joint (in the hub) - I managed to remove the rounded bolt by using an 18mm socket on the top.. and hey presto the bolt came off no bother..
Then came the hard bit.. the old ball joint would not move.. took me an hour atleast.. I wasn't giving up.. I decided to take the top seal off the ball joint, removed the plastic lip that covers the ball joint and the joint came out. Then used my wee propane butane torch and heated it then rust spray and chisel hammer then hammer and chisel from the top in a sequence for about 20 mins and wholla the ball joint casing came out.
I wish I had done this earlier instead of wasting time on it. But lesson learnt for when I am going to do the drivers side. All put back now and just need to torque it up to spec
 Current:
Past:
Post #479435 26th May 2018 8:03pm
johnboy17
seized ball joints
Hi Scotcruz
How did you rremove the top cover of the ball joint? Have given mine a good hammering but no luck so far. Thanks John
Post #480168 5th Jun 2018 6:03am
scotcruz
Johnboy.. it's fairly straight forward and easier than I thought.
Basically the top cover is made of aluminium so if you use the screw drive and hammer to poke through it then work your way to take the cover off which is pressed in. Takes about 10 mins max.. once this is off, there is a white plastic bit pressed into it which basically keeps the ball in place. Again use a flat screwdriver and break the plastic. Once this is out the ball will simply pull up. Takes about 5 mins
This then exposes the inner metal which is not rusted and more receptive to heat. My good old butane propane torch came in handy.. and then I used the sds hammer drill to take it out.. the whole process took me 30 mins. Whereas before this, I had spent atleast 2-3 hours and it didn't move at all.
Hope this helps, give us a shout if you need any help Current:
Past:
Post #480325 7th Jun 2018 1:28am
johnboy17
seized ball joints
Had a go and at last had success!! Many thanks for your reply
Post #480329 7th Jun 2018 5:06am
scotcruz
Superb mate..
It was a relief and when I replace the drivers side control arms/ ball joint it will be a walk in the park.. Current:
Past:
Post #480393 7th Jun 2018 11:42pm
johnboy17
Have done both sides now. Offside ball joint did not need replacing so it was much easier. Good luck.
John
Post #480398 8th Jun 2018 6:22am
scotcruz
I've bought the full kit so will probably replace it all and I know its done and good for another few years Current:
Past:
Post #480490 8th Jun 2018 11:06pm
