![]() | Home > Technical (L322) > Front air suspension fitting |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35643 ![]() ![]() |
have you read this?
Cooper1275 Member Since: 02 May 2016 Location: Dublin Posts: 117 ![]() ![]() ![]() |
well dont i feel like a silly plonker |
StewD Member Since: 22 Apr 2016 Location: Glasgow Posts: 129 ![]() ![]() ![]() |
Biggest drama you will definitely have is removing the bottom bolts. I used a full sized sledge hammer and it was still a complete pig of a job. Once all the bolts are out it’s a straight forward enough job. Make sure you have lots of time to spare. Current: Supercharged 06 FFRR in Java Black
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 395 ![]() ![]() ![]() |
The wiki says to re-use the old airline connector, though I've also heard that the new airline connector shouldn't be removed from the new airbag as o rings can be disturbed and you should cut the airline and feed this into the new connector on the airbag.
I reused the connector as it seemed the easier option. Have had no issues since. Current: Supercharged 06 FFRR in Java Black
