Home > Technical (L322) > Front air suspension fitting
Cooper1275
Ireland 2006 Range Rover Vogue SE Td6 Buckingham Blue
My front drivers side bag started hissing yesterday so I am looking at how to swap it out.
I have ordered 2 new delphi front units from Island 4x4. (based on the strong feedback here Delphi vs Dunlop etc)
L322 Range Rover - How To Depressurize Air Springs
L322 Range Rover - How To Replace Air Springs
&index=8&list=PLY_7KaC4JPbSA22G-Ho-uWVI3SXVcmbIk&t=171s
If my bag is already hissing and dropping down when parked will i need to do step 1?
I have access to a 4 post ramp so i am not looking for short cuts but i dont want to poke at stuff that should be better left alone. Thumbs Up
Post #480098 4th Jun 2018 10:28am
have you read this?
http://www.fullfatrr.com/gallery/thumbnails.php?album=359 ... - .- -.
Post #480099 4th Jun 2018 10:36am
Cooper1275
well dont i feel like a silly plonker Embarassed
Thanks Stan this place is a wealth of knowledge Thumbs Up
Post #480101 4th Jun 2018 11:15am
StewD
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Biggest drama you will definitely have is removing the bottom bolts. I used a full sized sledge hammer and it was still a complete pig of a job. Once all the bolts are out it’s a straight forward enough job. Make sure you have lots of time to spare. Current: Supercharged 06 FFRR in Java Black
Previous: BMW 740D M Sport
Previous Previous: BMW 730D Sport
Post #480160 4th Jun 2018 10:32pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
The wiki says to re-use the old airline connector, though I've also heard that the new airline connector shouldn't be removed from the new airbag as o rings can be disturbed and you should cut the airline and feed this into the new connector on the airbag.
Anyone else heard this advice? Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #480171 5th Jun 2018 7:34am
StewD
I reused the connector as it seemed the easier option. Have had no issues since. Current: Supercharged 06 FFRR in Java Black
Post #480280 6th Jun 2018 7:38am
