Home > Maintenance & Mods (L322) > Range rover car jack
Serg7681
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi guys,can anyone recommend hydraulic trolley jack to capable lift Range rover L322
Thank you
Post #479385 26th May 2018 5:26am
There are some, but trolleys big enough tend to be expensive. Get a Mercedes sprinter jack. Does the job better than any trolley.
If not then Clarke do a high lift 3t trolley which is pretty decent. There is nothing that can't be fixed with a hammer😜😜
Post #479387 26th May 2018 6:45am
Serg7681
Cheers pal πŸ‘πŸ‘πŸ‘πŸ˜πŸ˜πŸ˜
Post #479390 26th May 2018 7:52am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
I have a Clarke 3 tonne. It's good but it is Censored heavy. Don't go for the quick lift one. Sure I've seen reports of them failing on the disco forum. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #479393 26th May 2018 8:58am
Serg7681
πŸ‘πŸ‘πŸ‘
Post #479394 26th May 2018 9:01am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
I've got 1 of the Clarke 3 ton jacks with the Quick lift feature.
It's a good jack, but as said, very heavy.
The Quick lift feature is almost no use, as if you're using the jack a long way under the car (eg from rear or front of car), you can't reach the quick lift arm. It's also a pain when lowering the car down, as the quick lift arm then lifts up & then is in danger of contacting / damaging the front spoiler / valance when the jack is at it's lowest.
I'm probably going to remove the arm from the jack .
Without it I think the jack is Β£10 or more cheaper (& a bit lighter - lol) Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #479396 26th May 2018 9:14am
Serg7681
OK ,will have to order todayπŸ‘πŸ‘πŸ‘
Post #479397 26th May 2018 9:17am
MikeO
Found the thread I was thinking of
https://www.disco3.co.uk/forum/clarke-ctj3...42205.html 2016 Skoda Octavia VRS Estate
Post #479402 26th May 2018 11:03am
