Home > Maintenance & Mods (L322) > Range rover car jack |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8512 |
There are some, but trolleys big enough tend to be expensive. Get a Mercedes sprinter jack. Does the job better than any trolley.
26th May 2018 6:45am |
Serg7681 Member Since: 13 Apr 2018 Location: Aberdeen Posts: 18 |
Cheers pal ππππππ |
26th May 2018 7:52am |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 517 |
I have a Clarke 3 tonne. It's good but it is heavy. Don't go for the quick lift one. Sure I've seen reports of them failing on the disco forum. 2016 Skoda Octavia VRS Estate
26th May 2018 8:58am |
πππ |
26th May 2018 9:01am |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 689 |
I've got 1 of the Clarke 3 ton jacks with the Quick lift feature. It's a good jack, but as said, very heavy. The Quick lift feature is almost no use, as if you're using the jack a long way under the car (eg from rear or front of car), you can't reach the quick lift arm. It's also a pain when lowering the car down, as the quick lift arm then lifts up & then is in danger of contacting / damaging the front spoiler / valance when the jack is at it's lowest. I'm probably going to remove the arm from the jack . Without it I think the jack is Β£10 or more cheaper (& a bit lighter - lol) Paul, 2001 Discovery 2 TD5, 211,000 miles & climbing 2006 FFRR TDV8 Vogue 145,000 miles & climbing Member of Midland (Land) Rover Owners Club, www.mroc.co.uk |
26th May 2018 9:14am |
OK ,will have to order todayπππ |
26th May 2018 9:17am |
Found the thread I was thinking of
26th May 2018 11:03am |
