Home > Technical (L322) > L322 Rear Brake Carriers
Brummie Rich
United Kingdom 2003 Range Rover SE Td6 Oslo Blue
Hi,
Can anyone help with trying to source a pair of rear brake caliper carriers for a pre '06 L322 (ATE brakes)?
I managed to get a new pair of calipers from Island 4x4 for £36 each but my carriers are deeply pitted.
I've cleaned them up but there are deep pockets worn in them where the pads sit and I'm sure It's not helping with the binding.
Ideally I'd like a new pair but the only ones I've found are the OE's at £90+ each .
Even a good used set would be better than the ones I've currently got.
I think there used to be an aftermarket product, but I can now only find them for post '06 models with the TRW braking system which are completely different.
Any help would be appreciated.
Post #479186 23rd May 2018 12:27pm
Embarassed
Post #479191 23rd May 2018 1:40pm
You might like to contact the seller on eBay on the page below by using "Ask a question"
He sells the Calipers for rear ATE system but for some reason also shows the carriers attached in some items.
He might be able to sell the carriers alone to you.
Post #479192 23rd May 2018 1:42pm
depends how much you rate the 'product' that stops your FF when you're happily cruising at 70mph..
get the proper ones from our site sponsor, dan @ duckworths ... - .- -.
Post #479199 23rd May 2018 2:35pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I believe I've got a pair somewhere.
Let me check and get back to you. Current:
- 2017 L405 3.0 V6 Autobiography
- 2013 L405 4.4 TDV8 Vogue [For Sale]
Sold:
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #479299 24th May 2018 7:33pm
Sandyt
+1
Post #479301 24th May 2018 7:54pm
Brummie Rich
I've worked in the aftermarket business for a long time so I know there's a big variability in quality out there.
The calipers seem well finished to be honest. I'll be using the RR a lot so they'll get a proper testing over the next few months.
I just don't want to have to strip them all off again if I can help it to replace the carriers.
Post #479355 25th May 2018 2:22pm
