Home > Technical (L322) > [SOLVED] Testing Battery Drain Instructions Help |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Hi
1st May 2018 10:25am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
"This where I get stuck. If I undo and remove the battery negative cable, there is no power to the car so the shut down routine will stop? Does it mean connect the meter between the negative earth cable and the negative battery post? If I do so the startup routine may cause a surge (also because it is cold my FBH seems to kick in, don't want to melt the meter cables)"
1st May 2018 2:01pm |
I got nothing back on the alternator cable test.
1st May 2018 9:40pm |
@ Meerbusch
1st May 2018 9:41pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I’ve not tried this but it should work.
3rd May 2018 11:25pm |
uzp315 Member Since: 19 Nov 2017 Posts: 428 |
Make sure you have access to both fuse boxes. You can switch off the interior lights with the switch on the light by the rear view mirror.
5th May 2018 8:02am |
Think my multimeter is knacked, can only read volts
5th May 2018 2:42pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
5th May 2018 3:44pm |
nah, I'm a cheapskate .
5th May 2018 10:31pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3776 |
I have got a couple of these clip on ammeters.
6th May 2018 7:57am |
Just stuff to be aware of if you are looking for a drain:
6th May 2018 8:14am |
Just disconnect the bonnet button
6th May 2018 9:37am |
I only looked for mine for a few seconds, and a friend suggested that they had done away with such troublesome things so I didn't look any further. How is the search going Joe90 did you check opening the diagnostic port to see if that reduced the drain? |
6th May 2018 1:13pm |
OK, some amps results from my clamp meter
19th May 2018 5:20pm |
