![]() | Home > Technical (L322) > [SOLVED] Testing Battery Drain Instructions Help |
Hi
"This where I get stuck. If I undo and remove the battery negative cable, there is no power to the car so the shut down routine will stop? Does it mean connect the meter between the negative earth cable and the negative battery post? If I do so the startup routine may cause a surge (also because it is cold my FBH seems to kick in, don't want to melt the meter cables)"
I got nothing back on the alternator cable test.
@ Meerbusch
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I’ve not tried this but it should work.
uzp315 Member Since: 19 Nov 2017 Posts: 428 ![]() |
Make sure you have access to both fuse boxes. You can switch off the interior lights with the switch on the light by the rear view mirror.
Think my multimeter is knacked, can only read volts
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
nah, I'm a cheapskate |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
I have got a couple of these clip on ammeters.
Just stuff to be aware of if you are looking for a drain:
Just disconnect the bonnet button
I only looked for mine for a few seconds, and a friend suggested that they had done away with such troublesome things so I didn't look any further. How is the search going Joe90 did you check opening the diagnostic port to see if that reduced the drain? |
OK, some amps results from my clamp meter
