Home > Technical (L322) > [SOLVED] Testing Battery Drain Instructions Help
Page 3 of 3 <123
@Joe90
If you are stuck for a solution to your battery drain problem you could fit a relay in the cable from fuse 49 and switch it from the ignition circuit. Not a total solution but a definite work round that will stop your battery drain easily and cheaply when the ignition is off.
I presume your battery drain shows up on fuse 49. Thumbs Up
Post #482013 27th Jun 2018 5:12pm
Kiamaria
My battery drain didn't show up anywhere until i pulled the connector on the neg lead module.
Post #482016 27th Jun 2018 5:43pm
@Kiamaria
Nothing on the negative terminal on an '02, but a good shout Thumbs Up
@ NDFI
May be worth a try Thumbs Up .
Post #482038 27th Jun 2018 8:40pm
Definitely on Fuse 49, amperage dropped to 0.05 amps when pulled and car asleep.
Navigation System
On Board Computer
On Board Monitor
Audio System
Will have to see if I can isolate further.... .
Post #482273 30th Jun 2018 4:04pm
Does you car have a Connect 2 box about the size of a packet of cigarettes in the wiring harness running below the TV module. It's part of the original car phone system. If so you could try removing it. Undo the two plugs connected to it and plug the plugs together. They are m/f and blue if my memory serves me correctly.
I initially had a current drain similar to yours on fuse 49 circuit, disconnected the Connect 2 and never had a battery drain since, 7 years. When I try and measure for one I consistently get zero.
When I opened the Connect 2 box I found water had got in it and one of the miniature relays in it had corroded in the closed position.
Threw the box away, technology has moved on.
Definitely worth a look, you might be lucky. Thumbs Up
Post #482282 30th Jun 2018 6:10pm
A good shout, but I have already removed it sometime ago and plugged the two connectors together Thumbs Up
Will it just be a case of removing the connectors from each item as above and seeing what happens? I have looked at the wiring diagrams and they all seem to be "daisy chained" on a red/green wire?
and from the wiring diagrams is the ECU-Navigation (D182) in the black satnav box in the rear cubby? .
Post #482290 30th Jun 2018 9:01pm
More testing:
Unplugged the SatNav unit (original unit), blue and purple plugs and aerial, and locked the car, once asleep amperage down to 0.035amps. So believe I am onto something.
Pretty certain the little red light on the satnav is going out when car is locked but will now check this. .
Post #482330 1st Jul 2018 11:35am
Try unplugging the aerial to the sat nav only. Leave the Satnav connected. Thumbs Up
Post #482331 1st Jul 2018 12:00pm
Decided to dismantle the satnav unit, which was/is working, to see if anything obvious inside.....
This was the underside of the PCB at the bottom front of the unit
Hmmm - what do you think Confused
Grabbed my can of DP-60 and a toothbrush and gave this and a couple of other areas a good scrub down. The rest of the internals of the unit were in good order, clean and shiny, no sign of blown capacitors or tracing/tracking.
Reassembled, no bits left over!, and back into the car, connected up and locked.
WOOHOO !! 0.025amps
Hopefully, job done. Thanks to all for their ideas, advice and pointers Thumbs Up Thumbs Up Bow down
FWIW, once you get the unit carrier off (may need gentle tapping with a small hammer) the top and bottom covers should just lift off with a little bit of prying, then you can unscrew the pcb and the player unit, unclip a few things and it all comes apart. .
Post #482337 1st Jul 2018 1:26pm
nino_nino
Very Happy Thumbs Up
Post #482347 1st Jul 2018 3:49pm
I wonder how many Satnav units have been scrapped when all they needed was their teeth cleaned.
Really good result. Thumbs Up
Post #482349 1st Jul 2018 4:20pm
GGDR
Great news Joe, well done!
. Cheers, Greg
Post #482356 1st Jul 2018 5:27pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Good find Joe. What is that mess? 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #482367 1st Jul 2018 7:40pm
I guess it is just corrosion from some previous water ingress, am guessing that this was causing a short of some kind, or quite simply, as often is the case Exclamation , the very act of dismantling and putting back together resolved the issue Very Happy .
Post #482378 1st Jul 2018 9:09pm
kgeddes
I’ve just had fuse 49 diagnosed for my battery drain issue. Still to confirm what component is the cause. Fuse 49 removed at the moment. Wish I’d seen this thread earlier! Evil or Very Mad
Post #592190 23rd Apr 2021 8:59am
Page 3 of 3 <123
