Home > Technical (L322) > L322 hi pitched bleeping noise / alarm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
while I was in spain I left my FF at a mates and he said the alarm had been sounding , the boot lid was open so I thought it must be that but lately its happening more often , it doesn't sound like the alarm but more of a hi pitched beeping which appears to last for around 30 seconds
is it the alarm OR something else ?? Confused
Post #477386 2nd May 2018 9:06pm
Do all the indicators flash when the beeping is happening, if so it is the alarm.
Cause...where does one start:
1. Spider in the car
2. Bonnet sensor button fubared
3. Electrical gremlin
Solution unplug the sounder Wink .
Post #477399 2nd May 2018 11:54pm
bembo449
Yes they do flash , so it must be the alarm and what a poxy thing it is !
What is odd is that after 10 hours parked at work it was fine yet at home since 7am it keeps going off , will have a snoop about but if all else fails will unplug the sounder . . . . Wherever that is
Cheers Joe
Post #477415 3rd May 2018 10:26am
You could try disabling the interior sensor by pressing the key fob twice. At least that would eliminate that.
Post #477417 3rd May 2018 10:33am
bembo449
I presume that sensor is in the panel in the centre of the roof ?
Post #477424 3rd May 2018 1:12pm
why dont you sort the bonnet switch first.. ... - .- -.
Post #477426 3rd May 2018 1:17pm
"I presume that sensor is in the panel in the centre of the roof ?"
It is. Thumbs Up
Post #477429 3rd May 2018 1:27pm
bembo449
must be pal as I disconnected it at 11am this morning and not had a peep out of him since , even with the sunroof open all day , need to see if there is anything wrong with the sensor though , not good to not have a fully operational alarm system
Post #477486 3rd May 2018 8:45pm
uzp315
I think the diagnostic system makes a loud repetitive beeping sound. Not entirely sure what it means, but when i pulled the fuse for it, I heard such a beep.
Post #477568 5th May 2018 8:04am
bembo449
well it certainly seems to be set off by lorries rumbling past it
Post #477672 7th May 2018 12:15pm
Why not; Park car,
Open Bonnet
Fool the bonnet switch into thinking the bonnet is shut.
Lock car.
Disconnect battery
Close bonnet.
Leave alone until needed.
Unlock car with key, open bonnet, re attach battery etc etc etc.... There is nothing that can't be fixed with a hammer😜😜
Post #477673 7th May 2018 1:09pm
bembo449
the above may be viable if I leave it parked up- for a few days butt for day to day its a bit of a faf , it still seems very random to me , parked outside for over an hour and the road as usual , similar amount of wagon's rumbling past etc but it never went off Confused
Post #477774 8th May 2018 7:02pm
bembo449
ive just been out and rocked the car while its locked / alarmed , nothing happened Confused , surely that should have set the alarm off ?
Post #477780 8th May 2018 8:02pm
Sorry, was working on the idea you had left it at a mates while you were away. Thumbs Up
It’s not near your microwave is it.... and no I’m not taking the Censored . Our silver Hilux is so bad that it has to be parked one space over from my oppo’s kitchen window. Also will go off if the phone is left in the locked car.
Just an idea. There is nothing that can't be fixed with a hammer😜😜
Post #477782 8th May 2018 8:25pm
bembo449
meant to update this a few days back , turned out to be the bonnet switch ! so all quiet now thankfully
cheers Very Happy
Post #478541 16th May 2018 5:50am
