Home > Technical (L322) > L322 hi pitched bleeping noise / alarm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Do all the indicators flash when the beeping is happening, if so it is the alarm.
2nd May 2018 11:54pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
Yes they do flash , so it must be the alarm and what a poxy thing it is !
3rd May 2018 10:26am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
You could try disabling the interior sensor by pressing the key fob twice. At least that would eliminate that. |
3rd May 2018 10:33am |
I presume that sensor is in the panel in the centre of the roof ? |
3rd May 2018 1:12pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35287 |
why dont you sort the bonnet switch first.. ... - .- -.
3rd May 2018 1:17pm |
"I presume that sensor is in the panel in the centre of the roof ?"
3rd May 2018 1:27pm |
must be pal as I disconnected it at 11am this morning and not had a peep out of him since , even with the sunroof open all day , need to see if there is anything wrong with the sensor though , not good to not have a fully operational alarm system |
3rd May 2018 8:45pm |
uzp315 Member Since: 19 Nov 2017 Posts: 428 |
I think the diagnostic system makes a loud repetitive beeping sound. Not entirely sure what it means, but when i pulled the fuse for it, I heard such a beep. |
5th May 2018 8:04am |
well it certainly seems to be set off by lorries rumbling past it |
7th May 2018 12:15pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8512 |
Why not; Park car,
7th May 2018 1:09pm |
the above may be viable if I leave it parked up- for a few days butt for day to day its a bit of a faf , it still seems very random to me , parked outside for over an hour and the road as usual , similar amount of wagon's rumbling past etc but it never went off |
8th May 2018 7:02pm |
ive just been out and rocked the car while its locked / alarmed , nothing happened , surely that should have set the alarm off ? |
8th May 2018 8:02pm |
Sorry, was working on the idea you had left it at a mates while you were away.
8th May 2018 8:25pm |
meant to update this a few days back , turned out to be the bonnet switch ! so all quiet now thankfully
16th May 2018 5:50am |
