Home > Technical (L322) > L322 hi pitched bleeping noise / alarm
told you so, its always the bonnet switch.. Thumbs Up ... - .- -.
Post #478548 16th May 2018 6:54am
uzp315
Is bonnet switch you refer to like this?
Mine keeps doing the beeping. But not when on battery charge (bonnet closed), or after a long run. I put a Ctek charger on is, and after 26 hours the charge was still going, so I assumed my 7 year old battery is duff even though it starts immediately every time.
Also, it usually does it twice, mid afternoon and then not again as far as I am aware.
I have bought a new battery but not yet fitted as I thought I would double check on what is the cause before just changing the battery.
If it is a simple switch, that is going to be a lot cheaper than a battery replacement.
Post #557057 9th Jun 2020 11:13am
uzp315
Disconnected bonnet switch and the alarm has not triggered for 24 hours. Progress.
Battery can go back for a refund, and a new bonnet switch can be bought for a fraction of the price. Result. Thanks FFRR!
Post #557268 11th Jun 2020 6:51am
