Home > Maintenance & Mods (L322) > Engine dies after hard acceleration |
rattly Member Since: 15 Oct 2016 Location: Cotswolds Posts: 42 |
Hi all,
25th Apr 2018 5:01pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2654 |
Need to get injectors checked first |
25th Apr 2018 7:23pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
As you have most probably read my recent post on a similar issue I would just change the external low-pressure pump. After a good run out today I am very confident that the new pump has solved my problem.
26th Apr 2018 2:12am |
Hi,
26th Apr 2018 7:38am |
The gearbox must be a torque thing, it makes sense to me that with inadequate fuel supply there is less power so the box will be holding low gears longer and changing down on hills. My box was rebuilt 2 weeks before I bought my car and has 40000klm on it so should be good for a while. It is quite incredible the change a new pump has made. When I get a chance I will plug the laptop back in to read the fuel low-pressure figure to see if it's up on the previous 4bar 2007 TDV8 VSE
26th Apr 2018 7:59am |
Disconnected fuel filter sensor, and yep, got the ping of doom!!! |
26th Apr 2018 9:07am |
So that's the sensor that monitors the low-pressure side, If you are getting the warning when driving, that to me signals the external pump is dying as suggested before. 2007 TDV8 VSE
26th Apr 2018 9:16am |
Just realised one more thing, its worse when the tank is under half full?? |
26th Apr 2018 11:41am |
Hi,
5th May 2018 2:49pm |
Thanks for the update, any tips on fitting the in tank pump, I have a new one ready to fit next week as a maintenance item. 2007 TDV8 VSE
6th May 2018 2:51am |
No prob... remove back seat etc etc.. Access is via both access panels, you`ll need long arms as you have to reconnect an electrical plug by reaching into tank from opposite access hole.. so less fuel in it the better!!
6th May 2018 2:09pm |
Rattly, Please advise, When removing the old pump/sender unit am I right thinking I can disconnect just the inner electric plug then remove the unit, nothing else attached? Once out can the hose on the pump be easily disconnected then reused or is it one of the hard plastic types that need to be cut and discarded, needing a new hose to refit. 2007 TDV8 VSE
7th May 2018 5:09am |
Hi,
7th May 2018 9:41am |
