Home > Maintenance & Mods (L322) > gearbox
lawsey
England 2015 Range Rover Vogue SE SDV8 Corris Grey
gearbox
I had the gearbox service done about 8k ago with genuine parts and oil. It appears to be losing drive for a couple of seconds when turning at junctions. In a straight line will go from 1st to sixth and back down again perfectly smoothly. there doesn't appear to be any leaks Does this point to incorrect oil level or something more serious? apart from the dealers does anyone know of a garage in the North East that could diagnose the issue? I will check oil level today and report back. MY 07 tdv8. 86,000 miles
Post #474311 30th Mar 2018 6:27am
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Are you sure the right spec oil was used? Who did the service? 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #474327 30th Mar 2018 9:58am
RRPhil
Maybe worth checking that the selector cable clamp bolt isn’t seized, through corrosion, in its hole in the lever
Phil
Post #474337 30th Mar 2018 11:12am
lawsey
well its got worse.. off to Austrin Gearbox Specialists today for diagnostics.. Any good rebuilders as memebers??
will update witg projected costing..
Post #475000 6th Apr 2018 12:54pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
^^ 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #475002 6th Apr 2018 1:28pm
lawsey
well they have checked it over, lubed the trans cable, checked oil.and road tested. Not losing drive?? so hopefully fixed. other than that no fault codes so try it for a week see how it goes??
Post #475594 12th Apr 2018 6:00pm
roblane65
For what it's worth I've used austrin before and they really seem to know their stuff diagnosed the transfer box fault in mine when I'd previously been told by another so called idependent they 99.9 % certain the transmission noise was the front diff and quoted £2300 for the repair , I wonder what they would have done when I picked it up and it still had the same noise Rolling Eyes Range rover 4.2 SC 06MY.
Post #475748 13th Apr 2018 6:52pm
