Home > Technical (L322) > One car coming close for sale! |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 |
Link from the disco 3 site https://www.disco3.co.uk/wiki/P023D Current 2007 TDV8 Vogue Buckingham Blue |
2nd Apr 2018 5:19pm |
Could also be a split top hose too which would be better than the other description on the link! Current 2007 TDV8 Vogue Buckingham Blue |
2nd Apr 2018 5:23pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Does it only put up the code when under heavy acceleration up hill for example ? |
2nd Apr 2018 11:06pm |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 744 |
That’s about right 2014 vogue se |
3rd Apr 2018 7:26am |
I've been chasing a turbo / map fault on a TD6 and have replaced the turbo solenoid, map sensor and vacuum pipes and had the turbo off twice to free up variable geometry vanes in turbo. The second time i removed it i found a split in the pipe next to the turbo. It would rive perfectly in most instances but up one particular hill where i would accelerate up from a roundabout it would get to around 3000 revs in third or fourth and then the revs would just drop and i would get a turbo / map fault, one being P0046 but the codes don't always seem to be as literal as they would suggest.
3rd Apr 2018 7:38am |
Have a check of the top hoses Current 2007 TDV8 Vogue Buckingham Blue |
3rd Apr 2018 8:29am |
New ones fitted two years ago! 2014 vogue se |
3rd Apr 2018 8:34am |
