Home > Technical (L322) > One car coming close for sale!
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Just about at the end of my tether with this car?.
Can any of you fine guys give me any pointers to this problem! Car pulls like a train, then for no apparent reason , flips up this code!!!
Found one little pipe under the rocker cover had broken away from its receiver, put it back on to no avail!
Many thanks
David 2014 vogue se
Post #474564 2nd Apr 2018 3:38pm
kbald
Link from the disco 3 site https://www.disco3.co.uk/wiki/P023D Current 2007 TDV8 Vogue Buckingham Blue
Post #474571 2nd Apr 2018 5:19pm
kbald
Could also be a split top hose too which would be better than the other description on the link! Current 2007 TDV8 Vogue Buckingham Blue
Post #474572 2nd Apr 2018 5:23pm
holidaychicken
Does it only put up the code when under heavy acceleration up hill for example ?
Post #474611 2nd Apr 2018 11:06pm
chefkenmore
That’s about right 2014 vogue se
Post #474624 3rd Apr 2018 7:26am
holidaychicken
I've been chasing a turbo / map fault on a TD6 and have replaced the turbo solenoid, map sensor and vacuum pipes and had the turbo off twice to free up variable geometry vanes in turbo. The second time i removed it i found a split in the pipe next to the turbo. It would rive perfectly in most instances but up one particular hill where i would accelerate up from a roundabout it would get to around 3000 revs in third or fourth and then the revs would just drop and i would get a turbo / map fault, one being P0046 but the codes don't always seem to be as literal as they would suggest.
If you have VGT / VNT type turbo then it would be worth searching to see if your actuator / vanes could be stuck but I would be trying to find any split hoses especially if you remapped your ecu.
Post #474628 3rd Apr 2018 7:38am
kbald
Have a check of the top hoses  Current 2007 TDV8 Vogue Buckingham Blue
Post #474638 3rd Apr 2018 8:29am
chefkenmore
New ones fitted two years ago! 2014 vogue se
Post #474641 3rd Apr 2018 8:34am
