Home > Technical (L322) > Will the airbag deploy?
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
I noticed that the light for the seatbelt does not come on when someone is using the passenger seat.It works correctly for the driver's side.
My main concerne is will the airbag deploy in the event of a accident with the safetybelt in use?Will it know there is someone using the passenger seat in the event of a accident??How does this system works?
I am aware that on some vehicles the airbag will not deploy if the safetybelt is not being used!!
Advice please!! 2012 TDV8 Vogue SE 4.4
Post #474562 2nd Apr 2018 3:00pm
From the earlier cars workshop manual it appears that both the passenger seat seat belt pretensioner and airbag will default to operate and deploy in the event of the passenger seat belt indication not working. Although a fault will be logged in the DCU provided the SRS warning light is not lit everything will work.
I would assume the operation is the same for later cars but it would be worth checking to be sure.
From the Workshop Manual 2002-2006
The driver and passenger airbags are fired in a frontal impact. The time delay between firing the two gas generators in each airbag decreases with the increasing severity of the impact, until, at the most severe impact limit (driver and passenger airbag 4), the gas generators are fired simultaneously. In a frontal impact, the DCU only fires the driver and passenger airbags if the safing sensor has closed, and also evaluates the inputs from the seat belt switches and the seat occupancy module before it comes to a firing decision.
If there is a fault with a seat belt switch input, the DCU assumes the seat belt is fastened for the pretensioner firing strategy and unfastened for the airbag firing strategy. If there is a fault with the occupancy detection sensor, the DCU assumes the front passenger seat is occupied.
Post #474575 2nd Apr 2018 5:41pm
Frans@Yamorna
Thanks for the reply!!No faults logged.
I checked the WM for my car but could find no reference to the working of the safetybelt or SRS system.Under what section of your WM did you find the reference!
Regards 2012 TDV8 Vogue SE 4.4
Post #474585 2nd Apr 2018 7:18pm
The section of the workshop manual I found a description of the workings was entitled "Restraint Systems" Thumbs Up
Post #474592 2nd Apr 2018 7:49pm
Frans@Yamorna
Thumbs Up Thumbs Up 2012 TDV8 Vogue SE 4.4
Post #474593 2nd Apr 2018 8:00pm
desertdude
United Arab Emirates 2003 Range Rover Vogue 4.4 V8 Alaska White
There is a passenger seat sensor sandwiched between the lower seat foam which tells the car if there is someone in the seat or not.
Post #475318 9th Apr 2018 6:08pm
Frans@Yamorna
How do one get to it? 2012 TDV8 Vogue SE 4.4
Post #475398 10th Apr 2018 7:01pm
you need to take the seat out and strip the base to get to the occupancy sensor.. ... - .- -.
Post #475406 10th Apr 2018 7:36pm
Frans@Yamorna
Thumbs Up Thumbs Up Big Cry 2012 TDV8 Vogue SE 4.4
Post #475438 11th Apr 2018 6:02am
