![]() | Home > Technical (L322) > Will the airbag deploy? |
From the earlier cars workshop manual it appears that both the passenger seat seat belt pretensioner and airbag will default to operate and deploy in the event of the passenger seat belt indication not working. Although a fault will be logged in the DCU provided the SRS warning light is not lit everything will work.
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
Thanks for the reply!!No faults logged.
The section of the workshop manual I found a description of the workings was entitled "Restraint Systems" |
desertdude Member Since: 10 Sep 2016 Location: Dubai Posts: 60 ![]() ![]() ![]() |
There is a passenger seat sensor sandwiched between the lower seat foam which tells the car if there is someone in the seat or not. |
How do one get to it? 2012 TDV8 Vogue SE 4.4 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35508 ![]() ![]() |
you need to take the seat out and strip the base to get to the occupancy sensor.. ... - .- -.
