Home > Technical (L322) > Maf sensor causing dpf full?
dirtymonkey38
Could a faulty maf sensor cause the dpf full error? I did the o-ring fix and oil cooler gaskets recently. I cleaned the maf sensor located in the intake manifold and ever since I’ve had problems with dpf full light coming on which I’ve cleared three times, but out driving earlier I now have the red dpf full light take to dealer and limp mode 2011 RR Autobiography 4.4 TDV8
Post #473686 24th Mar 2018 11:21am
Baltic Blue
Their is a thread on here somewhere about cleaning the MAPT sensor, but even when they are really clogged up and dirty their is no history of it causing DPF alarms.
They are usually more caused by splits in one or more of the 4 short hoses.
Post #473688 24th Mar 2018 11:50am
dirtymonkey38
Didn’t notice any when I took it apart. It was fine before though so a bit strange. Now I’m getting “water in fuel condition” on my scanner 2011 RR Autobiography 4.4 TDV8
Post #473692 24th Mar 2018 12:37pm
you can drain the water out of the fuel filter by undoing a screw underneath the filter... ... - .- -.
Post #473697 24th Mar 2018 1:09pm
Any other fault codes?
Post #473725 24th Mar 2018 7:17pm
dirtymonkey38
Can somebody do me a favour and take some pictures of their intake hoses from above and end on? I’m NOT convinced they are set up correctly and are leaking air causing false readings.
Will have a look at fault codes again later. 2011 RR Autobiography 4.4 TDV8
Post #473802 25th Mar 2018 10:55am
Baltic Blue
d...m38,
These are the later modified type hoses.
The originals are a much softer more pliable type of rubber.
Post #473807 25th Mar 2018 11:09am
