Home > Technical (L322) > Maf sensor causing dpf full? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3778 |
24th Mar 2018 11:50am |
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 |
Didn’t notice any when I took it apart. It was fine before though so a bit strange. Now I’m getting “water in fuel condition” on my scanner 2011 RR Autobiography 4.4 TDV8 |
24th Mar 2018 12:37pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35416 |
you can drain the water out of the fuel filter by undoing a screw underneath the filter... ... - .- -.
24th Mar 2018 1:09pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Any other fault codes? |
24th Mar 2018 7:17pm |
Can somebody do me a favour and take some pictures of their intake hoses from above and end on? I’m NOT convinced they are set up correctly and are leaking air causing false readings.
25th Mar 2018 10:55am |
d...m38,
25th Mar 2018 11:09am |
