Home > Technical (L322) > Not turning over |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
alfapat
23rd Mar 2018 7:04am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35412 |
i'd start with a brand new battery first...
23rd Mar 2018 7:21am |
Not sure , don’t know.
23rd Mar 2018 8:04am |
Would anyone qualify the proper rated battery other than the one that Halfrauds suggest please, which is either 95Ah or 100Ah with 900 cca . My own one is 800 cca |
23rd Mar 2018 10:45am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1536 |
Try moving the gear lever a little bit in Park. It could be the switch - mine plays up sometimes.
23rd Mar 2018 10:55am |
Ok looks like a Varta 020 looking on here.
23rd Mar 2018 11:00am |
Ok can’t rplicate the fault under the console, so would any of the plugs inhibit the starting process if they were dodgy, would the only way out is to remove one by one to see ? |
24th Mar 2018 4:05pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Could be the ignition switch, often a cause of problems.
24th Mar 2018 5:33pm |
Ok will check that out tomorrow, every time I move released console cover , it relates to wire movement , if you get me? |
24th Mar 2018 8:52pm |
All starter connections good , working well at the moment! |
25th Mar 2018 1:34pm |
ok spoke too soon , its not turning over again , I have most of the centre console and cant see anything untoward.Its bee ok since my last post , so I need to know where the starter relay is , word is its behind the battery in the blsck box , but there is a light brown one , but I thing its light green and so I cant find it , does anyone know please. |
6th Apr 2018 3:30pm |
Also what does the Battery squib do and is it part of the starter relay system , what oother than connections should I be looking for please? |
7th Apr 2018 9:13am |
Having a read about squib , I left it a lone! |
7th Apr 2018 5:42pm |
NVB Member Since: 14 May 2017 Location: Essex Posts: 103 |
I had similar symptoms which I cured with a new starter motor. RR History
8th Apr 2018 10:39pm |
