Home > Technical (L322) > Wheel bearing |
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 |
I’m getting an occasional high pictched, fast “wob wob wob” sounds form the rear my car. Starts at around 50MPH. Any ideas? Bearing? I’m just about to change the rear brake disks and pads as I I have a judder under braking. Also an upper knuckle suspension bush as just starting to ware. |
19th Mar 2018 9:00am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Got any wobble on the wheel?
19th Mar 2018 10:54am |
One of the bushes needs replacing, so might make it difficult to be sure. But I don’t think there is any play. |
19th Mar 2018 10:56am |
Cooper1275 Member Since: 02 May 2016 Location: Dublin Posts: 117 |
Could be a sticky brake caliper?
19th Mar 2018 11:40am |
One of the disks is scored and I have brake judder from the rear. Sounds like I should get a wheel bearing along with the disks and pads. |
19th Mar 2018 12:06pm |
Change the calipers on both sides along with the discs and pads.
19th Mar 2018 12:36pm |
Mines on 81k miles. Will change the calipers too. Do you recon the fast wob wob wob noise is the calipers sticking, or do the bearings at the same time to be sure? |
19th Mar 2018 12:51pm |
The wob wob wob is the pad rubbing off the disc and squeaking.
19th Mar 2018 1:07pm |
Thanks everyone. I have had a few niggles with my car and every time the help and advice has been invaluable. |
19th Mar 2018 2:21pm |
