![]() | Home > Technical (L322) > Wheel bearing |
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 ![]() ![]() ![]() |
I’m getting an occasional high pictched, fast “wob wob wob” sounds form the rear my car. Starts at around 50MPH. Any ideas? Bearing? I’m just about to change the rear brake disks and pads as I I have a judder under braking. Also an upper knuckle suspension bush as just starting to ware. |
Got any wobble on the wheel?
One of the bushes needs replacing, so might make it difficult to be sure. But I don’t think there is any play. |
Cooper1275 Member Since: 02 May 2016 Location: Dublin Posts: 117 ![]() ![]() ![]() |
Could be a sticky brake caliper?
One of the disks is scored and I have brake judder from the rear. Sounds like I should get a wheel bearing along with the disks and pads. |
Change the calipers on both sides along with the discs and pads.
Mines on 81k miles. Will change the calipers too. Do you recon the fast wob wob wob noise is the calipers sticking, or do the bearings at the same time to be sure? |
The wob wob wob is the pad rubbing off the disc and squeaking.
Thanks everyone. I have had a few niggles with my car and every time the help and advice has been invaluable. |
