![]() | Home > Technical (L322) > 2011 fuel gauge |
tj2k Member Since: 10 Dec 2017 Location: Shropshire Posts: 34 ![]() ![]() ![]() |
Hmf, Stratstone quoted:
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 750 ![]() ![]() |
As a guide I reckon I could do the whole job in under 2 hours now I know where everything is and how it comes apart, obviously it took me a lot longer than that but I’m a cautious amateur.
Just had this back from Hatfields (Mike is the parts guy):
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Are you able to send the bulletin to Stan for inclusion in Wiki ?
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 ![]() ![]() ![]() |
Is this any good?
Ok, very long post with pics follows:
Sorry can’t help with your suspension problem but can suggest some pump removal help.
So, both faults fixed but I had a bit of a game on mine:
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 ![]() ![]() ![]() |
Having just done this job I can second tj2k's comments about being careful releasing the pump spring clamp. I also lost the bar / spring and then spent 5mins with my hand in the tank trying to find the bar only to discover it drops into the pump assembly. Having put it back together the |
Well done 👍My house stank of diesel for a long time afterwards! |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
ive also just done this job on my 2010VSE tdv8
Mine is the same year and I have a fuel sender 2 issue. Is that the easy one to sort or do I have to remove the pump? I don't get much time off from work so would need to plan well in advance! Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
I don't know which one is which but it's a relatively easy job to do what dexion7 did and you have a 50% chance of success. You only need to remove the right hand cover plates and reach inside.
i dont have an OBD tool either so don't know which code relates to which sender. i can say however that when you unplug the external fuel tank connector, the left most pair of 2 pins (8 pins in a line) go to the most easily accessible internal connector. put your ohm meter across each pair of pins BEFORE you pull it apart. if you do this and the strange reading is the left pair then you are in luck and should have the easy fix. as i said in my last post, the way that internal connector just hangs there is not very good and it probably minutely flexes every time you go around a bend resulting in fretting. good access is possible to the first internal connector and unplugging / replugging a few times might be a 100% solution. the second pair of wires for the other sender's internal connector (both sender units have a black and a blue wire) can be seen dissapearing off somewhere else in the tank (presumeably access to that connector is only possible after removal of the other, left, access cover). however, the fretting which takes place is just that - "fretting" as apposed to "pitting". pitting is caused by arcing from high current and microwelds with high resistance whereas fretting doesn't and means you can move the male and female pins relative to each other and thus hopefully resume a point of good contact. why is this relevant? well, since the current flowing across the pins in the connectors is very low, even a poor connection between the male and female pins will be ok and (just my guess) the effects of fretting on the inaccessible internal connector might be negated simply by gentle tugging on the wires which go to it. like i said, mine had this problem a few years ago and it went away an returned 20k miles later. once you have had the right cover off and replugged the acceible one and tugged a little on the other one i reckon you have a pretty good chance of fixing it. also, you mentioned the time involved - try doing a dummy run which just involves external stuff like learning how to get the trim off etc and meauring the reistance. fitting the trim bakc on is really quick too. you will then find that the full job including the in tank work is simple (assuming you don't need to pull the pump!) |
