Home > Technical (L322) > RR 3.6 TDV8 2008 - Gear Box Service Kit and Torque convertor
alangrig
Latvia
Dear All,
time has come to change oil in automatic gearbox - ZF 6HP26 (Range Rover 3.6 tdv8 2008). Additionally, car experiences revs fluctuation between 1.5k & 2K (https://vimeo.com/259877650). During acceleration around 30mph-40mph you can feel slipping. As a result, I'm planning to:
1.Buy ZF fluid service kit+additional ZF longlife fluid
2. Buy new or remanufactured torque converter.
3. Perform megaflush.
In this regard, I will appreciate any opinion on the matter as follows:
1. Reliable seller in UK for ZF transmission parts! I came across http://www.sussexautos.co.uk/zf-car-parts.php, but have no idea how good is this company?
2. Buy new or choose remanufactured torque converter? I haven't seen new one for sale, only manufactured. I came across different companies across UK, but I am not sure which one to go with. I have been looking into this one: https://www.ebay.co.uk/itm/Range-Rover-Vog...1438.l2649
Any ideas are welcome and very appreciated.
Rgds,
Alex[/img]
Post #472242 12th Mar 2018 9:52am
Dolphinboy
Sussex auto have a good rep on here I believe. Do a search for Sussex and you will see lots of threads about torque converters (normally the td6 rangeRover)
Most remanufactured are probably ok. Try JPat in bristol uk. https://jpat.co.uk/index.html
See here
http://www.fullfatrr.com/forum/topic38818.html?highlight=sussex
Post #472243 12th Mar 2018 10:01am
alangrig
Latvia
Dolphinboy,
thank you, will check for JPA.
Post #472244 12th Mar 2018 10:05am
Dolphinboy
Hi, just updated my post with correct company name.
Post #472245 12th Mar 2018 10:08am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
i know a pal on the bay who does the heavy duty t/c which ive given a chap to use and his was spot on and no issues, item number:
eBay Item No. 302439645248 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #472265 12th Mar 2018 1:34pm
Mikey
How many miles has the vehicle in question covered?
Post #472267 12th Mar 2018 1:54pm
alangrig
Latvia
Mikey,
the vehicle has covered 150,000 miles so far.
Post #472417 13th Mar 2018 2:11pm
alangrig
Latvia
thank you, appreciated!
Post #472418 13th Mar 2018 2:12pm
alangrig
Latvia
Thanx a lot!
Post #472420 13th Mar 2018 2:14pm
alangrig
Latvia
Here is video, how revs fluctuate, even while cruising:
Post #472423 13th Mar 2018 2:51pm
Mikey
alangrig wrote:
Mikey,
A flush, or even an oil change is likely to make things worse
At the very minimum, it needs a new TC Thumbs Up
Post #472471 13th Mar 2018 6:33pm
alangrig
Latvia
Mikey,
thank you!
Post #472476 13th Mar 2018 7:03pm
Tight777
I stand to be corrected but I think Vanmatic in Hayes supply a lot of the auto gearbox trade with parts.
020 8848 9911
Torque converter symptoms for me were, 1600-2000 rpm, felt like going over a cattle grid.
(Max torque)
Post #472484 13th Mar 2018 7:31pm
alangrig
Latvia
Tight777
thank you. Based on given information, I am now considering full rebuild of gear box:
1. Torque converter
2. ZF 6HP26A repair kit
3. Oil
I presume it is the way to go in order to avoid any further failure after gearbox reset and further adaption process
I am afraid that oil and torque converter change might cause failure because of incompatibility with other worn out parts of the gearbox.
What do you think?
Post #472669 15th Mar 2018 8:01am
philt350
Wales 2008 Range Rover HSE TDV8 Barolo Black
TDV8 pre-cursor to gearbox failure
Hi all.
I have an '08 tdV8 which has covered 90k miles, with full service history. Even though the gearbox seems to work ok it does whine and whistle excessively in the lower gears. Just wondering is this normal (dont think so) and is this an indication of imminent failure? I think it has had a gearbox flush about 8 months back, before I bought it. What are the symptoms of torque convertor failure? I think the vehicle has done a lot of towing in it's early life - could this be reason for whining / whistling?
Cheers,
Phil.
Post #473239 20th Mar 2018 7:57pm
