![]() | Home > Technical (L322) > RR 3.6 TDV8 2008 - Gear Box Service Kit and Torque convertor |
alangrig Member Since: 03 Jan 2016 Location: Riga Posts: 26 ![]() ![]() |
Dear All,
Sussex auto have a good rep on here I believe. Do a search for Sussex and you will see lots of threads about torque converters (normally the td6 rangeRover)
Dolphinboy,
Hi, just updated my post with correct company name. |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
i know a pal on the bay who does the heavy duty t/c which ive given a chap to use and his was spot on and no issues, item number:
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
How many miles has the vehicle in question covered? |
Mikey,
thank you, appreciated! |
Thanx a lot! |
Here is video, how revs fluctuate, even while cruising:
A flush, or even an oil change is likely to make things worse At the very minimum, it needs a new TC ![]() |
Mikey,
Tight777
philt350 Member Since: 04 Sep 2017 Location: Holywell, Flintshire Posts: 5 ![]() ![]() ![]() |
Hi all.
