Home > Technical (L322) > 2010 front callipers |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2492 |
Hubs and knuckles are the same, but discs and brake pad wear sensors are different.
12th Mar 2018 7:40pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8594 |
Not sure that the 6 pots are a direct fit from the 4.4, might be, might be an easier and somewhat cheaper job to look at putting the 4 pots from the 07-09 3.6. Discs and pads are cheaper and tbh they stop the car plenty well enough. There is nothing that can't be fixed with a hammer😜😜
12th Mar 2018 8:14pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16295 |
The 09> revision was fitted with a later type hub unit which means ONLY 09>12MY brake callipers will fit 09>L322’s sir...
12th Mar 2018 11:07pm |
The splash shields / backing plates are the same part number for both styles of brakes so do not require changing.
13th Mar 2018 1:36am |
its me Member Since: 08 Mar 2013 Location: southampton Posts: 78 |
I have done this conversion on a 07 supercharged and it has made a huge difference when towing a heavy load. I had to change the hub carriers, the disks and obviously the callipers. The disk shield and the speed sensors are the same. I got a pair of hub carriers secondhand and new callipers at very nearly half the price from Landrover. There are another two sets of callipers from where I got mine if anyone wants a pair. Ray. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion |
13th Mar 2018 8:01am |
