Home > Technical (L322) > 2010 front callipers
Kiamaria
Hi
Quick question?
Will later 4.4 TDV8 Range Rover Vogue front callipers fit an earlier 2010 3.6tdv8 Range Rover Vogue hub.
Are the hubs compatible with the later callipers? is the disc the same size?
thanks in advance
Steve
Post #472296 12th Mar 2018 7:27pm
GraemeS
Hubs and knuckles are the same, but discs and brake pad wear sensors are different.
In countries such as Oz that had the 5.0 na in the MY11/12 were fitted with the MY10 brakes whereas the 5.0 SC and 4.4 TDV8 had the 6-pots.
If you do the upgrade, I'd like to buy the brackets and spacers and possibly the calipers from you to fit to my MY12 4.4 to allow specific 18" rims to fit.
Post #472297 12th Mar 2018 7:40pm
Not sure that the 6 pots are a direct fit from the 4.4, might be, might be an easier and somewhat cheaper job to look at putting the 4 pots from the 07-09 3.6. Discs and pads are cheaper and tbh they stop the car plenty well enough. There is nothing that can't be fixed with a hammer😜😜
Post #472301 12th Mar 2018 8:14pm
The 09> revision was fitted with a later type hub unit which means ONLY 09>12MY brake callipers will fit 09>L322’s sir...
So, to answer the OP’s question... To upgrade your brakes you will need the 6 pot callipers from the 4.4TDV8. You will also need to change the front discs, brake pads & wear sensors and the rear backing plates too (dust covers)
Post #472339 12th Mar 2018 11:07pm
GraemeS
The splash shields / backing plates are the same part number for both styles of brakes so do not require changing.
MY11-12 5.0 SC brakes are the same as 4.4 TDV8
Post #472343 13th Mar 2018 1:36am
its me
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Brake convershion
I have done this conversion on a 07 supercharged and it has made a huge difference when towing a heavy load. I had to change the hub carriers, the disks and obviously the callipers. The disk shield and the speed sensors are the same. I got a pair of hub carriers secondhand and new callipers at very nearly half the price from Landrover. There are another two sets of callipers from where I got mine if anyone wants a pair. Ray. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion
Post #472355 13th Mar 2018 8:01am
