![]() | Home > In Car Electronics (L322) > IID Tool newbie - I'm hooked |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
Did someone say that a CCF edit puts all your audio settings back to default?
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 ![]() ![]() ![]() |
Thanks GAC23; that might explain this conversation the other day, whilst on a long drive:
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
^^brilliant
Just tried it twice. Battery held out but CCF seems screwed. E.g. Mirrors no longer dip in reverse. Setting in dash set to on. Also tried locking then unlocking but no good.
Unless I’m mad - always possible - the first time you plugged your IID in, it will have made a CCF backup.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Greg, when playing with IIDTool I always connect Cteck charger (set to supply) to avoid low battery problem.
Third time lucky - Worked!!
I've now got: - Blip sound on lock and unlock - DRL's - Numeric speedo in speedo - one press super lock And other stuff back online: mirrors are dipping on reverse again, cruise control is back and forward alert has come back online. Must have been a glitch in the matrix. Thanks team! Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Thanks Nino, I'll get a Ctek
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3789 ![]() ![]() ![]() |
Greg/ Nino,
Glad you’re sorted. |
Mike, what cteck you have, mine is 7A and it is sufficient and my battery is original factory so is going on 6.5 years old. |
Nino,
Greg/ Nino,
V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
