Home > Technical (L322) > 2003 L322 KEY NOT WORKING IN DOOR LOCK
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
I recently discovered after a flat battery and not being able to enter my L322 2003 via the fey fob, that when I tried the key in the door it would also not unlock.
Research reveals the door lock has 2 cables which operate the inner and outer door handles, these work perfectly but it doesn't show how the key in door lock works.
I am thinking some lever or cam might be broken they operates the lock latch assembly.
Does any one have a picture or info on how the key lock works, I don't want to pull everything off yet.
thanks in advance
Post #471600 8th Mar 2018 7:12am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi,
Here’s a link to YouTube for a powerfuluk video explaining how the door lock is removed.
It’s very simple, only one bolt and it’s out there’s no cables involved. The problem is that usually it hasn’t been put back properly.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #471605 8th Mar 2018 8:12am
lounge_on_wheels
Thanks Simon for the vid , looking at the vid I should be able to remove the grommet and unscrew that hidden screw to remove the lock and see if something is broken on it without taking the door card off.
Very Happy thanks
Post #471616 8th Mar 2018 9:33am
andygts
My old RR had this problem, someone had removed the lock in the past and not refitted correctly, there is a rod that links the actual barrel to the mechanism, when refitting it had to be inserted into the mechanism or else it misses and slides underneath.
It's a very quick fix, the video around 3:50 shows it perfectly Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #471621 8th Mar 2018 10:00am
UK Marine
Very Happy thanks
No problem hope it all goes well Thumbs Up ______________________________
Simon
Post #471623 8th Mar 2018 10:08am
