Home > Technical (L322) > 2003 L322 KEY NOT WORKING IN DOOR LOCK |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 828 |
Hi,
8th Mar 2018 8:12am |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
Thanks Simon for the vid , looking at the vid I should be able to remove the grommet and unscrew that hidden screw to remove the lock and see if something is broken on it without taking the door card off.
8th Mar 2018 9:33am |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 350 |
My old RR had this problem, someone had removed the lock in the past and not refitted correctly, there is a rod that links the actual barrel to the mechanism, when refitting it had to be inserted into the mechanism or else it misses and slides underneath.
8th Mar 2018 10:00am |
No problem hope it all goes well ______________________________ Simon ______________________________ Range Rover Classic 3.5 efi - Gone Range Rover Classic 3.9 efi - Gone Range Rover Classic 4.2 LSE - Sadly gone Land Rover 110 3.5 - Gone Range Rover P38a 4.0 SE - Pleased it's gone Range Rover P38a 2.5 DHSE - Just sold Range Rover L322 4.4 v8 Petrol - Current |
8th Mar 2018 10:08am |
