Home > Maintenance & Mods (L322) > Tyre presssures?
V8 VOGUE
2003 Range Rover Vogue 4.4 V8 Zermatt Silver
Tyre presssures?
I have tried to find this answer with no luck!!
I need to know the crrect pressure i should have in my tyres...285 / 35 / 22 please.
Post #47075 23rd Jan 2011 11:01am
thats not an OE size so trial and error..i would start at 34 psi.
Post #47077 23rd Jan 2011 11:07am
bogie
yeah, its easy for OE tyres as its on the sticker inside the door jamb on most cars
33 front 36 rear for 4 people load
bump it up to 36/40 if 5 people + luggage etc cheers
bogie
Post #47079 23rd Jan 2011 11:12am
dan_uk_1984
Incorrect differential in tyre pressures between front and rear will lead to premature center diff failure Thumbs Up
Post #47088 23rd Jan 2011 12:20pm
V8 VOGUE
I dont want OE pressure!!!
Post #47095 23rd Jan 2011 1:07pm
you've got some suggestions Rolling Eyes
no one knows the correct pressure because there isn't one , you have to try different ones until you are happy...
Post #47099 23rd Jan 2011 1:25pm
What make are the tyres .........
Vredestein quote 39psi front & 42psi rear for Wintrac Xtremes &
Ultracs are 39psi front & 38psi rear.
How the tyre has been designed will determine the correct pressure.
Post #47103 23rd Jan 2011 1:31pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Why? letters not necessarily in the right order
Post #47106 23rd Jan 2011 1:47pm
I use lower pressures in Winter Conditions and higher when on high speed motorway work. The Door Jam Pressures are only there to ensure LR do not get sued and are bit on the high side IMHO.
Post #47109 23rd Jan 2011 2:19pm
dan_uk_1984
Dixy wrote:
Why?
Because the transmission is designed to allow a certain amount of slippage. If you've changed the rolling radius of the tyres (specifically the front rather than the rear or vise-versa) then one axle's wheels will be travelling faster than the other.
The same principle applies left to right and can cause front/rear diff failure quite quickly too.
This is why the fronts are X and the rears are Y rather than the same all round. Also why different pressures are given for different loadings as this also changes the rolling radius.
In the L322 incorrect front/rear pressures usually manifests itself as vibration felt at speed, similar to wheels being out of balance.
The Workshop Manual also makes speciffic reference to the tyres being at the correct pressures to maintain correct operation of the EAS.
Post #47118 23rd Jan 2011 3:57pm
My advice: get a nice set of OE LR 20" alloys and Tyres and then you can refer to the sticker on the OSF door pillar for pressures and bonus feature, it won't screw up your transmission and you won't look blinged but cool. Very Happy Discovery 4 HSE
Post #47142 23rd Jan 2011 4:55pm
V8 VOGUE
They are yokohama, somebody must know exact pressure
My last chance is mate who works for bmw , he said they do a 22 inch upgrade for the x5
so bit of luck can give me some idea!!!
Post #47733 26th Jan 2011 9:46pm
dan_uk_1984
I think judging by the lack of answers no-one knows.
Not sure if anyone on here has put 22" on his Range Rover... Kinda not the point.
btw - the manufacturer of the tyre bares no resemblance to the pressure Confused
Post #47735 26th Jan 2011 9:53pm
let your mate tell you then..
the only answer you are going to get is going to be a suggestion of the psi because no one will know the exact pressure due to the tyres being non-standard for a RR...
the pressures for standard tyre sizes have been provided by the manufacturers who liaise with the tyre companies... ... - .- -.
Post #47736 26th Jan 2011 10:00pm
nbunney
Overfinch / K Censored hn
may know
Post #47779 27th Jan 2011 9:52am
