Home > Maintenance & Mods (L322) > Can anyone recommend snow foam that actually works |
TDSIX Member Since: 18 Feb 2017 Location: Stirlingshire Posts: 210 |
I did mine today and took a couple pics for you..
1st Feb 2018 6:37pm |
Oh it was pretty bad.. i'm not suggesting I just sprayed foam on it and blasted it off.. not at all.. I did..
1st Feb 2018 7:47pm |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
Snow foam attachment bought - thanks for link.
1st Feb 2018 7:48pm |
You can use a 50/50 mix with water and you get a good foam you can work with. For Gillette, use a 50/50 mix with hot water.
1st Feb 2018 7:56pm |
To finish.. I use this stuff. autogym express wax..
1st Feb 2018 8:03pm |
So - excuse the daftness - mix it 50:50 in the attachment. Then connect to pressure washer and use? What do I put here then? |
1st Feb 2018 8:27pm |
Yeah as easy as that.. half fill the bottle with product then top up the other half with water or hot water. 2010 FF 4.4 TDV8 Vogue - Gone
1st Feb 2018 8:51pm |
Thanks.
1st Feb 2018 9:35pm |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
Thanks tdsix.
1st Feb 2018 9:57pm |
Life shine is bullshit. It's just the same autoglym cleaning products you get elsewhere but marketed to folks that buy a used car, kidding them on their car will stay clean forever for an extra £150 detailing session
1st Feb 2018 10:27pm |
Thanks.
2nd Feb 2018 12:02am |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2567 |
The only supposed benefit of snow foam is that it’s touchless - i.e. you’re trying to remove dirt without inflicting swirls. My experience is that it’s only of real use on a car which is already properly waxed or sealed - otherwise it just isn’t aggressive enough to lift any dirt.
2nd Feb 2018 11:03am |
Correct.. the snow foam will only remove a light coat of dirt from a well waxed surface. If you let the dirt build up it will leave a film that needs sponged away. TFR traffic film remover will remove this with just a spray and rinse but is aggressive to use frequently, ideally you'll need to wax if you use that. Instead of TFR, you can spray a good coat of snow foam and sponge the film off, keep cleaning the sponge.. the foam acts like shaving foam and lubricates hopefully causing less swirl marks.
2nd Feb 2018 3:14pm |
Couple of times a week ?!?
2nd Feb 2018 5:03pm |
