Home > Maintenance & Mods (L322) > Cylinder number 8 multiple misfire code |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 |
Finally got my HEI spark tester. Spark looks good and regular. I've already tested the plug which is good. As I said before the fuel injector is ticking indicating it is working. I assume the only thing left is a dirty clogged fuel injector. Anything else I might have missed? I planned on taking the fuel rail off and replacing the fuel injector. Is that the best way to go about it or should I just put fuel injector cleaner in the tank and go run it hard on the highway. |
26th Jan 2018 8:04pm |
Update: I finished the #8 fuel injector replacement with a reconditioned one from eBay for $20. If the weather was better I would have done the valley pan while half way there. It took a while for the fuel to fill the rail. Then of course the battery was too weak so it needed a jump. Once it fired up and came out of high idle it was still running rough and the flashing service light was there. Same #8 misfire. I was not pleased. I need to charge the battery so I kept running it. As I'm keeping the idle up I realize I didn't reset the steering angle so I did the lock to lock with the wheel. Stilling running rough but no service engine light and iidtool not showing that fault. I clear all the faults. As I let it idle I notice the flickering of interior lights and display lights have stopped flickering. Seems to running normal again. Maybe it just took a bit to get all the air out of the fuel rail. Time will tell. |
30th Jan 2018 3:09am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
See how it goes, it is probably not over happy at having a low battery, like you say give a drive around to see if things improve.
30th Jan 2018 8:14am |
Any update with yours? I have been looking at my CATs and something a bit odd as the temp going in on one side was 175 Deg C and about 75 deg C coming out or around those figures and it has had two bottles of cataclean and a damn good thrashing and it’s been a lot better with temps on the cats much higher on both sides and it’s been pulling great again but I still think my cats are not right . |
5th Feb 2018 11:36pm |
I have about 75 miles on it since the injector swap, vacuum line replacement and air intake to throttle body gasket fix. Runs great and no service engine lights. ....knock on wood. I have run a bottle of techron on an 1/8th tank and another is in the full tank. |
6th Feb 2018 2:10am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Great news however strange! Current stable:
6th Feb 2018 7:30am |
Good news then |
6th Feb 2018 8:05am |
What seems strange Dan? |
6th Feb 2018 2:58pm |
