Home > Technical (L322) > RSD - Random Suspension Drop? SOLVED
Page 1 of 3 123>
GGDR
So was sitting inside tonight on the sofa with a film on. A bit of second screen action, checking fullfatrr.com too of course (film wasn't that great). Then I hear the FF alarm going off.
Went outside fearing a broken window but found the rear suspension both sides had dropped right down. I figure the movement set the alarm off. I've had one other RSD (Random Suspension Drop) maybe six moths ago but nothing since.
Started her up, no errors on the dash. Took the height up and down; off road then down to access height. Waited then repeated, engine running. Pumped up and down fine. (interesting it will wait for you to shut the door). Still no errors. Left it in access height and locked it.
I realise this could be a whole world of valves, airbags, receivers and compressors. But hopefully not and it will be level in the morning and I can chalk this up to RSD.
Has anyone experienced this then it's been fine again?
Greg Cheers, Greg
Post #464599 14th Jan 2018 10:26pm
GGDR
Just to update - seems fine a few days on
Greg
. Cheers, Greg
Post #464998 18th Jan 2018 12:27pm
not the rears but my front dropped about 2cm after i stopped and locked up ..happened once a few days ago but no alarms though..
voodoo? ... - .- -.
Post #464999 18th Jan 2018 12:35pm
nino_nino
last winter my car dropt 2" over night, it was -17C. car started no problem suspension went up, no faults recorder and never happen again. Very Happy
Post #465004 18th Jan 2018 1:12pm
GGDR
Mine dropped overnight again.
Raised fine on start.
. Cheers, Greg
Post #466431 29th Jan 2018 9:38am
Sandyt
Mine used to drop on cold nights changed both front springs and struts hasn't done it since But they were on 120k miles and 9 years old
Post #466438 29th Jan 2018 10:03am
nino_nino
how cold was it Greg?
Post #466486 29th Jan 2018 4:45pm
GGDR
Not too bad - I think maybe 9 degrees overnight. 2 degrees tonight.
interesting point Nino, you're thinking cold weather related.
It's same as last time - both rears evenly dropped.
Greg Cheers, Greg
Post #466510 29th Jan 2018 7:54pm
nino_nino
why don't you try and park the car the other way around. it may be worth a try?
Post #466528 29th Jan 2018 9:20pm
GGDR
You mean upside down Nino? Very Happy Very Happy
Not sure how to do that. Hold on.
ok I found and instructional video:
(I'm sure many have seen this before, keep it rolling until 20secs in)
Rolling with laughter Rolling with laughter
But seriously, I'm on level ground - so not sure what you mean...
. Cheers, Greg
Post #466531 29th Jan 2018 9:42pm
nino_nino
Laughing Laughing Laughing ,have seen the video before, some drivers are something aren't they?
didn't know whether your parking space is leveled or not.
Post #466534 29th Jan 2018 10:00pm
nino_nino
Greg, just found this on a US site:
http://www.rangerovers.net/forum/6-range-r...ssues.html
Post #466811 1st Feb 2018 9:11am
marcochezzi
South Africa 2011 Range Rover Vogue SE 5.0 SC V8 Fuji White
Mine still drops the front overnight, was only when below 5 celcius, now dropping 2 odd inches irrespective of temperature.
Stripped and cleaned the valve block, nothing, used another valve block, nothing, still drops same as before.
Read somewhere that its the o-ring seals in the air springs themselves.., have 2 new bags from JLR on my garage shelf waiting for an opportunity or a moment of desire..
Post #466823 1st Feb 2018 11:56am
GGDR
thanks nino and marco, great leads.
As mine is pretty infrequent, I'll keep an eye on things.
Since the rears are both dropping evenly, I think maybe not springs.
Otherwise just one corner would drop right?
Unless the circuit is joined?
The self levelling system is also a bit of a mystery to me.
I sat in traffic once on bit of a slope and felt it doing a bit of self levelling.
But other times not.
Greg
. Cheers, Greg
Post #466918 2nd Feb 2018 7:54am
marcochezzi
Yes, self levelling happens from time to time, I disconnected my battery when running tests to make sure that was not the reason for the overnight drop, still the same.
The 2 circuits interconnect at the valve block, but the valves are closed at power down, so if one bag leaks, the other does not drop, so by default you think that since both go down overnight at the same time it cannot possibly be the bags, but alas I think in fact it is, equal wear / damage to the bag o-rings..
At least thats what I keep telling myself given I have cleaned the valve block, properly, twice, and also because i spent a small fortune on new bags still to be fitted... Rolling Eyes
Post #466953 2nd Feb 2018 11:25am
Page 1 of 3 123>
