Home > Technical (L322) > RSD - Random Suspension Drop? SOLVED |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Just to update - seems fine a few days on
18th Jan 2018 12:27pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35331 |
not the rears but my front dropped about 2cm after i stopped and locked up ..happened once a few days ago but no alarms though..
18th Jan 2018 12:35pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
last winter my car dropt 2" over night, it was -17C. car started no problem suspension went up, no faults recorder and never happen again.
18th Jan 2018 1:12pm |
Mine dropped overnight again.
29th Jan 2018 9:38am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2265 |
Mine used to drop on cold nights changed both front springs and struts hasn't done it since But they were on 120k miles and 9 years old |
29th Jan 2018 10:03am |
how cold was it Greg? |
29th Jan 2018 4:45pm |
Not too bad - I think maybe 9 degrees overnight. 2 degrees tonight.
29th Jan 2018 7:54pm |
why don't you try and park the car the other way around. it may be worth a try? |
29th Jan 2018 9:20pm |
You mean upside down Nino?
29th Jan 2018 9:42pm |
,have seen the video before, some drivers are something aren't they?
29th Jan 2018 10:00pm |
Greg, just found this on a US site:
1st Feb 2018 9:11am |
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 96 |
Mine still drops the front overnight, was only when below 5 celcius, now dropping 2 odd inches irrespective of temperature.
1st Feb 2018 11:56am |
thanks nino and marco, great leads.
2nd Feb 2018 7:54am |
Yes, self levelling happens from time to time, I disconnected my battery when running tests to make sure that was not the reason for the overnight drop, still the same.
2nd Feb 2018 11:25am |
