Home > Maintenance & Mods (L322) > Front windows not working
Doonhamer
Hmm . . had the embarrassment of having to open the driver's door to get my security pass checked on the way in to work this morning Embarassed , even though it was working fine last night when I got home. Tried the driver and passenger door buttons but neither would lower the windows, but the rears are both working. I'll have a look at things at the weekend but the fuse must be okay as the central locking is working and with the engine off but the ignition on, I can hear a quiet 'click' when I operate either of the front buttons. My starting point will probably be the control unit - I've already looked at the Wiki on how to remove the door card - but has anyone got any experience of this problem and the way they solved it? L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Suzuki Grand Vitara XL7 - sold
Mitsubishi Pajero 2.8 - part ex'd
Hyundai Santa Fe 2.0 td - sold
Mitsubishi Pajero 2.8 - sold
Post #457348 15th Nov 2017 9:40am
Doonhamer
So - I'm currently sitting on the drive outside the house with the driver's door card removed. Put the replacement switch on but none of the windows would work! Put the old one back on and it will operate the rear windows up and down but fronts still inop. Rolling Eyes Checked everything I can see to check fuse and wiring-wise but nothing obviously wrong. Wondering if a battery disconnect with everything put back together first might be worth a try? L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Post #464266 12th Jan 2018 11:41am
SinbadRose
I take it you tried the hold it in up position for XX seconds, then down for xx seconds etc which is the reset for when they have locked
Might be of no help
Post #464267 12th Jan 2018 12:04pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Have you tried using your remote to open the windows. Hold down the unlock button and all of the windows / sunroof should open. After that hold down the lock button to close them all again, this will at least let you know if the electrical circuit to the motors is ok.
Good luck.. ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #464268 12th Jan 2018 12:17pm
Doonhamer
Sinbad / Simon
Thanks for the input, I'll try both ideas - no sunroof on mine but hopefully your method might throw some light on the matter. The front passenger window works from the passenger button button not the master switch pack.
Fingers crossed . . . . L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Post #464274 12th Jan 2018 12:38pm
Doonhamer
Good news and bad - holding the unlock button down opened all the windows! Master switch pack raised the rears, psgr side raised the psgr side - but nothing will raise the driver's window! Big Cry
Hmmmm . . . . L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Post #464279 12th Jan 2018 1:01pm
UK Marine
Hold down the lock button..... ______________________________
Simon
Post #464281 12th Jan 2018 1:09pm
Doonhamer
Tried that a couple of times, Simon - nothing doing . . . . . L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Post #464284 12th Jan 2018 1:21pm
SinbadRose
So you used the up button on the driver window and held for 10 secs and then down for 10 secs (something like that. If the window is locked because it thinks something has been stuck in there.
Post #464285 12th Jan 2018 1:29pm
UK Marine
Do you have an IIDtool? If so I believe you can activate various things like the windows.. ______________________________
Simon
Post #464286 12th Jan 2018 1:33pm
Doonhamer
And now the battery is too flat to do anything! Crying or Very sad Can see this turning into one of those days - Domestic Zero not happy cos I've spent all day so far trying to sort it, she's just gone out with granddaughter in buggy, muttering something about going 'stir crazy ' being stuck in the house all day! Censored
Simon- Can see a trip to local 4x4 specialist coming on - hopefully they can plug me in and at least get the window up before the weekend . . . . L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Post #464289 12th Jan 2018 2:07pm
UK Marine
I have a feeling this is a knackered switchpack replaced with a dodgy one. Not much help I agree.
A specialist might be able to activate that window but I would fully charge the battery, do a reset and then try again yourself.
Good luck my friend ______________________________
Simon
Post #464293 12th Jan 2018 2:58pm
Doonhamer
Well, the battery is disconnected and hooked up to the charger, I'll see how things go later this afternoon when it's fully charged. Gary at Newbury 4x4 saved my bacon yesterday afternoon, using his plug-I diagnostic to power the window up so at least I know the motor is OK - reckon it's either the replacement switch pack or a problem in the wiring in the door.
To be continued . . . . L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Post #464528 14th Jan 2018 2:13pm
UK Marine
Thumbs Up ______________________________
Simon
Post #464580 14th Jan 2018 7:43pm
Doonhamer
Problem sorted! The breaker's sent me a replacement switchpack, tested before they took it off the donor vehicle - and I now have front windows that go up at the touch of a button! 😀 L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Post #466524 29th Jan 2018 9:03pm
