![]() | Home > General > Is it worth buying a second hand diesel ? |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
Looking to change y 4.2 ideally looking for a 5.0 but they are like rocking horse poop so is it worth buying a diesel 4.4 short term or better to wait for a 5.0 ?? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35508 ![]() ![]() |
i changed from a 4.2 to a tdv8 Sandy and i'm glad i did...i now dont worry about the fuel consumption and this benefits greatly on long trips...
I remember you changing to a Westie my only reason for changing is that the RAC cover I have is only vehicles up to 11 years old and mine is 11 in June but drives beautifully and no faults
i've noticed that as well ..i think the 5.0 are more expensive as well... ... - .- -.
A couple of 5 were over 30k which is 4.4 405 territory might just hang of till May and see where prices are then |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
If you opt for an early L405 4.4 tdV8, make sure to check that it has had the turbo drain mod done otherwise you could have problems with the new MOT smoke tests they are talking about.
Good feedback I do about 20k a year with at least two runs down to South of France and am getting a bit hacked off with refuelling stops |
One question how is it on a motorway say accelerating from 60 to 100 abroad of course |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Am sure there was a 5.0 in the For Sale section on here? Alex
you defo wont have a problem on the 'acceleration' on tdv8 Sandy....and you'll find the engine will idle at around 1500rpm at 80mph.. ... - .- -.
Sandyt,
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7975 ![]() ![]() ![]() |
I find the problem is keeping the speed down |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3762 ![]() ![]() |
We have both 5.0 SC and 4.4 SDV8 in the family, whilst the SC is only 1 second faster to 60, the 4.4 SDV8's pick up from 60 to 100 is brutal - it just doesn't give up due to the Torque with no flat spots. Trust me whilst a supercharged is quicker in a drag run it will not shake off an SDV8 which will be snapping at its heels all the way - does anyone drive like that normally ? Making the minute difference between the two immaterial. Plus the V8 Diesel returns 28/35 and the SC 12/18 mpg 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
After all the comments I am leaning towards a 405 diesel I think so will have a look around |
