![]() | Home > Technical (L322) > Sump plug won't come out |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1549 ![]() ![]() |
Hmm, I like that. The existing plug has a magnet but is too short.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I prefered the helicoil as it leaves everything as standard size but you are then screwing into steel rather than aluminum so it will be a lot stronger and wont wear out.
Lathe? I'm not a trained fitter and turner, I'm an electronics tech. I can do simple stuff on the lathe but I've never tried thread turning.
Lathe thread cutting |
Forgot to add that there is nothing stopping you from making it out of steel |
I have temporarily fitted one of these sump plugs. The thread is about twice as long as the original BMW plug. For the first time since I have owned the car, there are no oil drips off the sump plug. |
The correct plug seals under the head with a copper washer and I previously used a bolt left over from my transmission rebuild with the integral rubber seal under the head as it was slightly longer and found some good thread.
